Viper's variable valve timing w/cam in block engine
This will explain vtec better than i could type it out
http://www.autozine.org/technical_sc...vvt_2.htm#VTEC
http://www.hotrocker.com/ What about this?
Actually Honda's VTEC uses two cam profiles, and a funky hydraulic actuator to choose the lobe. There is an actual switch over from the small lobes to the big which is audible. That goes back to at least the '99 Civic Si, and I think the Preludes had them before then.
EDIT: I have been hoping solenoid technology would advance to a point that constantly variable everything as far as valve timing is concerned for years now.
Then I am way behind on VTEC because the VTEC I read about was just advancing or retarding the cam.
Honda has the VTEC listed as meaning Variable Valve Timing and Electronic Lift Control. Yeah, I know, the acronym is horrible, but that is taken straight from a brochure about the system when it was first introduced.
vtec on honda/acura started back with the NSX. it was the first VTEC motor. the vtec that we're all familiar with comes on a variety of 4 cyl engines (b series, H series, D series, etc). even single cam motors can be vtec. my beater civic is a 97, 1.6L SOHC VTEC automatic with 210k miles on it.
two intake valves per cylinder, but three cam lobes. (the DOHC models have the same thing on the exhaust side, but the SOHC models only have 1 exhaust valve) an oil pressure solenoid that locks the three follower/rocker arms together to ride on the middle cam lobe which has a higher lift/duration than the "low lobe"
the newest versions of vtec, like found on the RSX and basically any K-series motor, is the same 3 lobe for 2 valve design, but it incorporates an advance and retard feature to increase mpg, and decrease the "vtec hit", making a smoother transition from the low lift to the high lift lobes
my old roommate showed hotrocker to me, and i have always wondered if anyone had it on their car. it seems like a good idea, but i would imagine it being a complete PITA to tune it.
oldschool
Feb 9, 2016 09:21 PM
Jul 4, 2005 05:00 PM
routesixtysixer
Jun 23, 2002 02:29 PM
