Variable duration lifters
Old Feb 5, 2005 | 12:51 AM
Capt'n Two Rotors's Avatar
I am putting the 847 in my stock lt1 here next week and was wondering if anyone had experience with Rhoades or any other variable duration/high intensity lifters. I know they will make a little noise but can't be worse than a solid lifter. Also what would I have to change in the Program to compensate, or can Madwolf or PCMFORLESS tune it? I have PCMFORLESS now but I ended up pretty much tuning myself and just using his tranny program. Any input is appreciated.
Troy
Old Feb 5, 2005 | 07:19 AM
Denny McLain's Avatar
Re: Variable duration lifters
Troy
It's been a long time, but I had them in a block Vette I owned and was very disappointed in them as yes…… they were noisier than solid lifters.
You can never ever beat tuning a particular car as each car regardless of similar mods seems to have individual personalities. If you have the capability to tune a car and access to a wideband 02 sensor, it’s really not very hard.
Old Feb 5, 2005 | 12:41 PM
I'm not to wooried about the noise or tuning the fuel I was more concernd with the knock sensor pulling timing, would I have to just disable it? If so how would I go about setting the timng? Did you notice any increased bottom end or drivability?
Old Feb 7, 2005 | 12:52 PM
Anybody?
Old Feb 7, 2005 | 01:03 PM
I had the complete engine redone so I have no baseline to tell if it picked up on the bottom end or not. Based upon the noise, I frankly don't care if it did or not as it sounded like you needed to adjust your lifters all the time.
This was a while ago and in a big block, so they may have improved or act somewhat differently now.
Old Feb 7, 2005 | 03:25 PM
atljar's Avatar
I had stock lifters on 847 and stock heads. You couldnt hear them at all, yet it was still enough to throw the knock sensor off the charts. I kept lessening its sensitivity, and yet it kept pulling timing. I finally just disabled it completely and relied on dyno tuning and listening for pinging. With a noisier lifter, its only going to get worse.
Old Feb 8, 2005 | 12:35 AM
So is the general consinsous that the problems out weigh the gains? This car is my daily driver so I want as much bottom end as I can get out of the 847. I know I will have to live with the idle and some drivabilty but just wanted to "help" it as much as I could.
Old Feb 9, 2005 | 08:55 PM
My assumption as to why so few have responded is the lifters you mention are very old technology and the 847 cam is a proven performer. Most of the bad habits can be resolved by tuning.
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
