valvetrain geometry issue
Old Apr 13, 2007 | 12:50 PM
  #16
mdacton's Avatar
Originally Posted by confused327
yes, i have been doing it with a gasket.
i'll have pics later today, i'm not at home right now and the camera should be charged by the time i get there.
do you know the base circle of the cam? you should not be having this problem so something must be getting overlooked.
Old Apr 13, 2007 | 02:21 PM
  #17
confused327's Avatar
no, as far as i know it is a regular magnum 270hr. would it list it on the cam card?
here are the pictures with the head gasket.
7.25
7.15(can only get set screw/lock 1.5 turns in, is this enough?)
Old Apr 15, 2007 | 01:44 PM
  #18
Pete Kane's Avatar
You are having the problem because you are using the springs. You need to remove the 2 springs on the cylinder you are checking and use light tension checker springs.
Old Apr 15, 2007 | 02:29 PM
  #19
i am, if you look closely you'll notice silver springs on the ones i'm checking and black normal springs on the ones i'm not.
i think i've decided that a 7.2 pushrod will get me closest to the center with out being too short.
Old Apr 15, 2007 | 05:56 PM
  #20
89TramsAmGTA's Avatar
I like the 7.250 pushrods from that picture. I like the sweep pattern and it is close enough to the center. 1.5 turns is not anywhere near enough.
Old Apr 16, 2007 | 06:51 AM
  #21
Pete Kane's Avatar
ummm...i am, if you look closely you'll notice silver springs on the ones i'm checking and black normal springs on the ones i'm not.
Ummmm, you are right. I am wrong . Sorry for attempting to help with your problem. I will not confuse your posts in the future.
Old Apr 16, 2007 | 07:30 AM
  #22
i didn't mean to offend anyone, sorry.
the 7.2 gives me 2.5 turns on the lock, and looks to have the same sweep pattern and just a bit closer to the center. and i already ordered them.
Old Apr 16, 2007 | 03:20 PM
  #23
Are you referring to the set screw inside the adjusting nut that has the 2 /2 turns?
Old Apr 16, 2007 | 05:06 PM
  #24
yes
Old Apr 16, 2007 | 09:52 PM
  #25
If it was me I would like to see more than 2 1/2 threads holding the lock screw in place. One option would be to install a shorter rocker arm stud. By shorter I mean on the upper half of the stud not the portion that screws into the head.
Old Apr 16, 2007 | 10:53 PM
  #26
I'll look into those, but I think that being screwed almost halfway in would be ok. I don't know how much these like to loosen up though, I didn't have any trouble with the stock nuts loosening with an xe268 and stock rockers in my 327.
Old Apr 17, 2007 | 02:55 AM
  #27
Projectz28's Avatar
Moderator
from what I can see the 7.2's look like they should be ok. I would not be comfortable with only half way in on the lock screw. Something isnt right there. I think you need shorter studs. The set screw should be in much further than that.
Old Mar 8, 2008 | 05:54 PM
  #28
marshall93z's Avatar
Back from the dead!
Did you ever figure this out?
HectorM52
Jul 30, 2017 11:46 AM
69z-28
Jan 29, 2016 10:46 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
vhgjk123
Jul 26, 2002 02:53 PM
