Valve train has broken apart TWICE in less than 800 miles!
Those springs are not set-up for solid roller.
They didn't dis assemble the heads and check everything? I have never seeen a complete head that was bought that was set up right. Thats why most builder want them bare.
post the pics....
sounds like you have alot of problems
post the pics....
post the pics....
post the pics....
The heads were disassembled when the porting was done, and he says th spring pressures were more than sufficient for the custom solid cam!? For those that don't know, the LT1/4 engine has a front mount distributor known as an opti-spark. When I first got the engine, it would not start. It turned out he installed it incorrectly.
What are the spring pressures etc? installed height open pressure? all that should be on the build sheet.
Let's keep this on topic..... TECH, not amateur lawyer stuff. Otherwise its gone.
Also sense a bit of negativism with your "Even in this section....." comment. People are trying to help you, and yet you can provide little if anything in the way of detailed info regarding the specific components used in the valve train, how it was assembled and adjusted, etc. Seems odd to put down the people who are trying to help you.
It was mentioned that the standard valve springs that come AFR 210 race readies are not sufficient to handle a solid set up-which would explain why these problems are happening.
Another thing that I'm wondering is why he installed aluminum rockers on the engine. I had a few people wondering (before I ever fired the engine) if they would even last given the application. I just accepted the builders judgment and figured he had a good reason for it; yet after the first failure, he switched all the rockers with steel ones?
I'm starting to wonder if the thicker head gaskets were put on because the piston-to-valve clearance was too close or even touching? I'm not going to speculate because I don't know enough about proper performance set-up's
The springs turned out to be ok. AFR says they're more than sufficient.
Interestingly, when he started taking apart the valve train, ALL of the push rods were breaking, or at least starting to.
There are waaaaaaaaaaay too many variables here for anyone here to help you, without having more detail and specs.
Just saying "those springs are good" means nothing. An engine builder should know what springs he is putting on a set of heads and he should know what they can, and cant do.
The springs were set up at AFR but the heads were dissasembled to be ported further? I am not sure I follow you there. You said race ready heads from AFR which would mean you had a set of heads ported by AFR. But you say they were dissasembled for porting... why? The entire top end of your motor needs to be gone over with proper measurements and tests to determine if it will work or not. The springs required are determined mostly by the cam. There are a few other items that can have an affect on proper spring pressure and installed height but for the most part the cam manufacture will tell you what to use. Not "they are good enough for a SR". Your cam is not that big honestly... I have a much bigger SR in my 355...
Also you can not tell how thich a head gasket is just by looking at it. If piston to valve clearance is wrong you do not adjust for it with head gaskets. You need to cut the pistons.
I also dont know why the builder would think its valve float... if he set up the springs he should know what they can do. If he just tossed in a cam without checking the springs first, you should find a new builder.
If you were losing power at 5000 rpm then someone really screwed up. A stock cam and springs will rev past 5k. It really sounds like you are either not getting the full story or your builder is not explaining to you what the problem is because you are not that familiar with what he is talking about.
BTW, FYI, this board is heavy with LT1/4 people and we are very familiar with an optispark...
I guess I forgot where I was posting. LOL
I'm a good judge of character. He seems genuinely concerned about making it right. He doing a leak down test on all the cylinders so I should know the status of that tomorrow.
