Valve train has broken apart TWICE in less than 800 miles!
Old Jun 12, 2008 | 01:12 PM
  #121
EnFuegoZ28's Avatar
Originally Posted by Built LT1
I finally got the motor back in late April and I've been waiting for a friend of mine to go through and inspect everything before it goes back in the car.
Just for the record, I let this engine builder rebuild it because he incurred all costs and wanted a chance to make it right; and I admire and respect him for that. At the same time, I think it's more than fair considering the results and the amount of money paid for his "expertise."
I was told it had bent valves and pushrods upon disassembly. The engine builder had no explaination of how that happened.
When I picked up the completed long block and took it to the guy that's going to inspect the rebuild work, he alreadly noticed problems with the valvetrain!
Notably, the rockers are not aligned properly. Apparently, the rockers need adjustable guide plates? Some of the roller tips are not centered on top of the valvestems. When it was pointed out to me it was grossly apparent. They're cross eyed and only touch the outer most edge of the valvestem! Not all valves were like this as some were more centered than others. The guy inspecting this also suspects that there are other problems with the rebuild such as insufficient valve clearance for the pistons; hence the repeated failures of bent and broken rockers, bent pushrods, bent valves, and the thickest head gaskets I've EVER SEEN on an engine! BTW-the head gaskets now are even thicker than the last ones!
One of the heads will be pulled off in the next few days and checked to see if they have ample clearance. I was told before by the engine builder that the PTV clearance was "more than enough" when I asked him if that was a possible factor in bending push rods. If the clearance is off, the motor will have to be disassembled to have the pistons clearanced or replaced. These are "custom JE nitrous pistons" ordered by the engine builder himself! I did not order "any" of these parts myself. There should be no reason for the PTV clearance to be off, unless it was overlooked the first time. And if that's the case, they shouldn't be in there now!
I'll stop speculating and wait for the facts...
As soon as I know the results, or any other information on this train wreck I'll post it here. Hopefully this headache will be over soon, 'cause I'm all out of aspirin.
It's like da ja vu. Same issues all over again. I understand letting this guy incur the cost and trying to get it right, but it seems he can't do it. Take it somewhere else and send him the bill. I'm sure the builder is tired of seeing your motor. Maybe a fresh set of eyes (hands) will get this motor in your car and you actually drive it. Seven months is a long time to be dealing with this.
Old Jun 13, 2008 | 12:14 AM
  #122
SS RRR's Avatar
I don't know why he put aluminum rockers on the engine to begin with. I'm actually hoping that someone on here could explain why someone would do that!
Not sure what cam profile you are running, but a good quality stud mount aluminum rocker like the Crane Cams Gold race rockers will do just fine for milder SR cams.
Old Jun 13, 2008 | 05:47 AM
  #123
bombebomb's Avatar
Did you ever get a quality build sheet? Cause for 15k you better have a crazy motor.
AdsoYo
May 2, 2018 03:21 AM
dale3in98
Feb 14, 2015 12:18 PM
mark0006
Feb 3, 2015 05:12 PM
Jazsun
Dec 29, 2014 12:14 PM
