Valve Tip Different Length?
Old Mar 1, 2010 | 11:39 PM
Meen95z's Avatar
Question Valve Tip Different Length?
I have lt4 heads with a hyd. roller cam and when the motor was being assembled the pushrod length was check and determined i needed 7.200 pushrods.. Ran it 4500 miles and had pitting in a few valve tips (ferrea valves), so i ground the tips just enough to get rid of the pitting. I checked them now and between the lowest and highest tip there is 30 thousandths. Is this something to worry about? Should I grind the longer valves match the short ones? Any help would be great, thanks
oldschool
Feb 9, 2016 09:21 PM
racecarz28
Mar 30, 2015 09:55 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Roadie
Feb 16, 2015 10:34 AM
CARiD
Jan 27, 2015 06:27 AM
