Valve springs and titanium top end
runner size 220cc
I plain to change out the exhaust valves every 10,000 or so miles, slightly used Ti exhaust valves are about the same $$$ as new high quality SS.
The trans is a TH700, I need to build it up with better every thing all most, starting with a $330 Hughes race over haul kit as the center peace along with other parts and servos, 10'' break away 3500 stall converter, and a heavy duty flex plate.
I'm going to can the stock drive shaft for an LT1 or inland empire drive line drive shaft and a safty loop.
The rear is gong to have to be a 10 bolt with a series III eaton posi I bought a while ago, some superior axels, 3.73 gears and a suporting cast Al diff cover and if I can't hook it on street tires I'll get some slicks.
The cars fat I think it is going to weigh about 3500lb.
I'm going to try and lighten up the frount and put it in the a$$ with a rear batt. Al heads light weight starter and other little things minus a lb. hear and there.
Originally posted by oil pan 4
runner size 220cc
runner size 220cc
The rear is gong to have to be a 10 bolt with a series III eaton posi I bought a while ago,... if I can't hook it on street tires I'll get some slicks.
The block is a 89 1 peace RMS 350 with 2 bolt mains (will be 2 stud mains once the crank gose in).
I was looking at an eagle 383 forged crank.
I was going to run 64cc Al heads and speed pro forged blower pistons and 5.7'' forged Hbeams.
It should give me about a 9.7:1 C/R
I didn't know the LT1 shafts were un balanced, I'll fork the 330 over for the inland empire part.
Maybe I'll stick one (LT1 drive shaft) in the V6.
I have a edelbrock duel plane intake manifold good for 1,500-6,500, part 7501.
The 7501 edelbrock intake, the 220 runers heads and that cam looks a lot like an edelbrock kit I saw a while a go that made like 450hp.
Unlike that Kit my heads have little bit bigger runners, The cam has the same duration but with more lift, the valves/ heads I have are 2.05, the kit had 2.02 I think and that kit was with a flat tappet cam, I have roller every thing. And I was going to do a little porting.
Might want to consider a Denny's Nitrous-Ready driveshaft. Indestructable and only $370. http://www.dennysdriveshaft.com/html/nitrous_ready.html
They also have a nasty Heavy Duty shaft for $270 to $310.
If you want an aluminum metal-matrix shaft, made by a company that does stuff for NASCAR, NHRA and is owned by the company GM started in 1923 here ya go... http://www.dynotechengineering.com/ I've got their 3.5" Al-matrix shaft and havn't had any problems even while blowing up 2 posi's.
