Valve spring oilers.
Old Mar 9, 2007 | 04:37 AM
95ttoplt1's Avatar
Has anyone used these?
Do they really produce a benefit?
Can you run them on a wet sump system?
Will the motor use more oil or smoke due to excess oil passing the valve stem seals?
I am looking to turn more RPM's than one probably should on the street and trying to maximize the life of the valve train components as much as possible.
Any input is appreciated.
Old Mar 9, 2007 | 01:15 PM
1racerdude's Avatar
They are not needed unless ya have blocked the normal way of oiling the top end.
Old Mar 9, 2007 | 01:34 PM
95ttoplt1's Avatar
Thanks for the input.
Why would you blcok the normal way of oiling the top end?? Are you talking about cam galley restrictors?
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
