Vacuum Pump
Old May 11, 2005 | 11:39 PM
Dave69Z's Avatar
Vacuum Pump
Is there any benefit to using a vacuum pump setup on a motor using standard tension rings? Or they used more for setups using low tension rings?
Currently looking at the pumps by Moroso and GPZ(?). May considering going this route after my new top end is on the motor. Pretty much a strip only combination that will see little if any street time.
Dave
Old May 12, 2005 | 12:14 AM
SStrokerAce's Avatar
Re: Vacuum Pump
Yeah it will help with windage... the new edition of the Engine Masters magazine has a good test on Vacuum pumps in it, you see more advantage with lower tension rings.
Bret
Old May 12, 2005 | 09:56 AM
Hot Rod Hawk's Avatar
Re: Vacuum Pump
Bret
Is this magizine on the store shelfs right now Bret?
Old May 12, 2005 | 02:25 PM
Re: Vacuum Pump
Yeah....
Has three different motors tested with vacuum pumps and traditional rings.
BTW you can always play with the oil ring expanders and a fish scale to loosen up the ring tension on the oils on your current setup if you add a vacuum pump and find more power.
Bret
Old Jun 28, 2006 | 09:35 PM
Z284thgen's Avatar
Re: Vacuum Pump
is the vac pump needed on a low tension ring more so then the std rings
if so then dang one more setup i gotta buy now
Old Jun 29, 2006 | 12:55 AM
WS6 TA's Avatar
Re: Vacuum Pump
Anyone know if you can just subscribe to that magazine? I didn't see any of the little send in blanks the last time I looked...
Old Jun 29, 2006 | 10:08 AM
Re: Vacuum Pump
I dont think so yet.
Bret
Old Jun 29, 2006 | 04:34 PM
95 Z/28 LT1's Avatar
Super Moderator
Re: Vacuum Pump
About the magazine, you will probably have to call them for a subscription. I had to do that when I subscribed to Super Rod.
Old Jun 29, 2006 | 06:56 PM
1racerdude's Avatar
Re: Vacuum Pump
Ya won't see much gain on the street,but ya will see accelerated wear from the fact that it takes away most of the splash oiling.
A standard set of rings don't need a pump and most recommend ya don't run one on the street.
Old Jun 29, 2006 | 10:52 PM
Z284thgen's Avatar
Re: Vacuum Pump
she's not much of a street car any more so im out to get all i can outta the new solid roller setup
Old Jun 29, 2006 | 10:53 PM
1racerdude's Avatar
Re: Vacuum Pump
If it's a trailer queen go for it.
Old Jun 29, 2006 | 10:54 PM
Z284thgen's Avatar
Re: Vacuum Pump
not just yet i will drive it to the track aprox 4miles one way total
mmf_1013
Apr 11, 2015 11:03 PM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
PurpleHaze95
Aug 21, 2002 07:56 AM
JurisAg02
Jul 27, 2002 11:49 AM
