Tool Questions dial bore gauge
Old Oct 1, 2007 | 06:47 PM
mdacton's Avatar
Opinions on tools
Looking at the B&B dial bore gauge, also what is the prefered type of mic to check crank cam etc.
Never considered a digital but should I? do the digitals convert from metric to standard if needed?
Any prefered brands on this type stuff and what else should I look into getting?
Old Oct 1, 2007 | 08:36 PM
MachinistOne's Avatar
Mitutoyo is pretty much the industry standard. Starret, Brown&Sharpe, SPI are also good gauges. I use the digitals because they convert in/mm, and will do step measurements. If you don't use them frequently it's an expensive investment for the digitals - the manual gauges can be had for $350-600 on ebay.
I use Sunnen dial bore guages.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
86ZZ4
Aug 22, 2002 08:50 AM
