tips on installing new springs on a Jesel Shaft mount s/u
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
well i began to pull "dead" and some broken (inner spring) valve springs.
i have the jesel shaft mount setup, and am using the moroso tool to do the swap. i have a good understanding, just wondering if you guys have any tips or tricks that make it easier to place the keepers in on the first try.
tia!
tia!
Re: tips on installing new springs on a Jesel Shaft mount s/u
yes thank you, that is one way i had considered, i just haven't tried it yet!
update.....grease orked like a charm as well as another tip from an ls1 tech board member
#6 is done
i used a small scerwdriver to help center the spring while is was compressed! worked like a frickin' charm!
thanks!
#6 is done
thanks!
