Timing
Old Nov 26, 2005 | 02:09 PM
RollForever's Avatar
Timing
I've been having problems with timing my car. People told me i should just set total timing with it. I have a Vac Advance distributor so am i supposed to keep it connected and time the car? Or do i plug the advance and time it? Could someone give me some tips on timing> Thanks
Old Nov 26, 2005 | 07:00 PM
1racerdude's Avatar
Re: Timing
What distributor ya got? Does it have a mechanical advance and how much?
Old Nov 26, 2005 | 09:54 PM
WS6T3RROR's Avatar
Re: Timing
if you want to set the timing take the vac advance hose off the dist and plug it so you dont have a vac leak. then set your timing, vac advance isnt active under wot because of the extremely low vacuum.
Old Nov 26, 2005 | 10:10 PM
1racerdude's Avatar
Re: Timing
He could have a MSD set up so as the mech advance is not all in until 4-4500 and it may be full advance at 38*. He may have to change the springs to get the initial timing right.
I agree,that you have to unhook the vacuum.
The factory does it for you and tells ya what to set the initial at.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
