Thin Head Gaskets for LTx cars
Old Mar 9, 2005 | 08:58 AM
  #16
CANTONRACER's Avatar
Re: Thin Head Gaskets for LTx cars
I used to run a .015" Felpro head gasket, part # 1094 I believe.
Never had a problem.
Old Mar 9, 2005 | 09:50 AM
  #17
Denny McLain's Avatar
Originally Posted by jonaddis84
Surprised nobody brought this up. What is the deck height of your block right now?
If it is any tighter than .010 you couldnt run a tighter head gasket anyway, safely at least.
Thanks for the input guys.
My current deck is .024 which is why I'm trying to get a thinner gasket. Also trying to figure out what to do on my next block also.
Old Mar 9, 2005 | 10:03 AM
  #18
I ran those gaskets because I was in the hole .030".
Old Mar 9, 2005 | 08:33 PM
  #19
OneFlyn95z28's Avatar
Those appear to be for a GEN-I motor not the GEN-II(LT1/4)
Maybe a different number?
Old Mar 9, 2005 | 09:10 PM
  #20
You have to open some of the water holes...
Old Mar 9, 2005 | 09:26 PM
  #21
TransAm-Z's Avatar
Originally Posted by chevyguy3
Mr Gasket #5716 is .026" and coated for aluminum heads, i have been using them on LT1s for years. they used to be special order, but for the last couple years both Summit and Jegs have now carried them in stock. only $35 a pair
I can see nothing at all wrong with this gasket...
1) It's cheap compared to stock gaskets or felpro.
2) It would bring my quenched height down to .041"
3) They claim no retorquing required.
So what's the deal? I have always found the cheaper solution hardly ever is the better one. Is there any special head and block prep required?
Old Mar 9, 2005 | 09:49 PM
  #22
jonaddis84's Avatar
As long as its a composite gasket, and you had composite gaskets on there before with no problems...then no.
Old Mar 20, 2005 | 09:31 PM
  #23
SILVERZZ28's Avatar
I'm .010 in the hole with a impy gasket. Never had any problems with the 1074s but now I have a blown gasket between 4-6.
From the plug I had a little heat in #6 but this would not have happened with the felpros.....
I'm going back to the 1074s unless someone can tell me the Mr. Gaskets are better
Old Mar 25, 2005 | 02:00 AM
  #24
vette40th's Avatar
http://www.cometic.com/
custom head gaskets, used by many High Compression and turbo /supercharged applications
Old Mar 25, 2005 | 03:03 AM
  #25
SStrokerAce's Avatar
If the Ra on the heads and block are good enough
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
