Which of these two cams are theoretically bigger?
Old Jan 16, 2007 | 11:19 PM
  #16
Built LT1's Avatar
Originally Posted by rskrause
I pretty much agree with Mike. I would add that IF everything else, especially the heads and the CR were EXACTLY the same the peak hp would be about the same with the smaller motor making the hp at SLIGHTLY higher rpm. The bigger motor would have more torque. Gear appropriately, there wouldn't be much difference between 1/4m. times as the smaller motor could use more gear. The bigger motor would make a nicer street combo, but they would be pretty damn close.
Why do you ask?
Rich
My new solid roller stroker has the larger cam. I know someone who is running the XFI grind on a 350. When I considered the relative cam specs and thier respective cubic inches I couldn't help but wonder.
dboone2172
May 16, 2015 07:45 PM
thenewkid
Apr 12, 2015 07:42 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Potent77
Apr 1, 2015 12:45 AM
