T-56 gears
Old Aug 29, 2002 | 02:32 AM
LewisW96's Avatar
Post T-56 gears
I have in my possession a '93 T56 and a '96 T56. I know the gear ratios are different but is there anyway to take the 5&6 out of the '96 and put them in the '93 trany. That would be the best of both worlds low 1 2 3 and high 5 and 6. I'm not sure how the 5&6 gears are messed with the rest.
Lewis
Old Aug 30, 2002 | 01:24 PM
Red_94Formula's Avatar
Post
yes you can interchange the gears. you can also have custom gears grinded to what you want.
Old Aug 30, 2002 | 03:26 PM
Eric Bryant's Avatar
Post
Yep, you should be able to interchange the 5-6 gears - they're seperate from the 1-4 stack.
I'm not sure what you're running for a motor or rear-end gears, but keep in mind that 6th is pretty high. My engine doesn't like to be lugged below 1700 RPM, so I don't even think about using it below 75 MPH.
Eric Bryant
'96 Impala SS (LT4 396, T56, "firm" suspension)
'96 GMC K2500 (parts hauler/dune runner)
'92 Roadmaster wagon (winter beater)
'01 Honda Accord LX V6 Coupe (wife's car)
http://www.bryantperformance.com
Old Aug 30, 2002 | 05:14 PM
LewisW96's Avatar
Post
For now I'm pretty much stock. I do have a CC 305 and some more bolt on stuff but I can drive in 6th(96) at about 1300RPM and I do not have trouble. I would like to go to a bigger cam and a good set of heads when I get my money right. I think I'll just stick with the complete '93 tranny for now. I also have a different rearend 3.23 gears. I found a calc. which says at 2K with the '93 tranny I will be running about 75MPH. Now with the '96 tranny I'll be just over 90MPH @ 2K.
I can get in alot of trouble at that speed.
Lewis
Old Aug 30, 2002 | 05:36 PM
Soma07's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by LewisW96:
I found a calc. which says at 2K with the '93 tranny I will be running about 75MPH. </font>
Yup, thats exactly what I run with my 93 tranny/3.23's.
Have you considered 6th gear out of a Z06? Its a .56 I believe, right between the 93 and 94+.
Jason
93 TA, M6
james007moore
Jan 1, 2016 01:14 PM
CARiD
Apr 8, 2015 08:08 AM
Duke
Jul 31, 2002 05:13 PM
