T-56 comparison help
Old Feb 10, 2003 | 09:43 PM
Strokt's Avatar
Hey guys, I was just wandering if some of you t-56 guru's could give me a hand here.
I need to now the difference in lengths of the bellhousings and input shafts between the ls1 and lt1 t-56s.
I know that the ls1 style is shorter and has a larger diameter input shaft, but i was needing to know the exact measurements.
I'm not expecting anyone to spoon-feed me the answers, just some links or something will be much appreciated.
Thanks,
Brett
Old Feb 11, 2003 | 06:18 AM
1LEThumper's Avatar
Act ually the LS1 trannies have a longer input shaft by about 2". The bellhousings just have a slightly different bolt pattern as SBCs do not have a center top bolt. However the 2 vertical bolts on both sides I believe are the same. Its just the other 2 that are different.
What else do you want to know?
Old Feb 11, 2003 | 06:41 AM
Strokt's Avatar
Thanks for the info. Do you know if there is any difference in the bellhousings, besides the slightly different bolt pattern, of the lack of a clutch fork. Once again, Thanks.
Old Feb 11, 2003 | 06:44 AM
1LEThumper's Avatar
LS1 cars do not have a clutch fork, they use a hyd. throw out bearing. The 2 are not compatable.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
TGGodfrey
Aug 18, 2015 06:08 PM
F'n1996Z28SS
Jun 3, 2015 09:39 AM
VentsWoker
West South Central
Nov 17, 2002 03:29 PM
