suggestions/opinions on 383 build for boost
Old Nov 5, 2007 | 12:20 PM
  #16
OldSStroker's Avatar
Originally Posted by rskrause
And not only am I talented, I am humble!
Rich
...as well as a Medical Deity.
Old Nov 6, 2007 | 12:24 AM
  #17
1racerdude's Avatar
Rich
Lord it's hard to be humble when you are perfect in every way,HUH.
Uhhh didn't they make a song 'bout that.
Old Nov 6, 2007 | 06:58 AM
  #18
rskrause's Avatar
Moderator
Rich
Old Nov 6, 2007 | 08:03 AM
  #19
LittleRedZ's Avatar
scat crank can handle the power no doubt about it, if it can handle teh beating my ysi+cog is giving out it should be able to hold what you going to give it.
Old Nov 6, 2007 | 08:21 AM
  #20
1racerdude's Avatar
Rich
Just joking with ya Doc.
No offense intended.
Old Nov 11, 2007 | 09:12 AM
  #21
blown94's Avatar
thanks for the input guys. Ill call callies this week and get a price. For what I see people doing with scat components I figured I could get away with the crank and rods and save a little, but Ill definitely call callies first and see because if its only a few hundred Id rather have the peace of mind of callies machine work and balancing in the bottom end of something Im going to push to the max. I know,.......cheap and forced induction dont go together, but im just trying to stick to a tight budget.
Old Nov 12, 2007 | 11:51 AM
  #22
roguedriver's Avatar
If your truely curious about the SRP's, i'll send you 2 of my broken -31cc ones that just got replaced with a set of JE -31cc extreme dutys. I'm on an Eagle assembly, 5.7 H-beams and ported LT1 heads. The SRP's let go in the setup i was running during my dyno vid in my sig. Broken lands. That was on 14psi and a 150 shot. If your planning close to 20 in the future with the spray also, those SRP's would get demolished. I don't believe they recommend past just 15psi alone on a good tune anyway. One very important thing to remember if your gonna build for this future setup is your ring gaps. You'll probably want to go with what ever the piston manufacture recommends for a "race" application for boost or n2o. Your ring gaps will probably need to be .027+ vs the lower .020's. I believe i made mine .027/.029 but i think others on the board here even run them wider. Your better to side on the looser side vs too tight. Heat = expansion and at 20psi, you'll be making a lot of it, which also means you'll need a lot of water/meth if your not gonna run an intercooler.
Ken R
Old Nov 13, 2007 | 02:49 PM
  #23
Ultra_Dog's Avatar
60,000 miles on JE -31cc pistons...
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
350350
14
Aug 11, 2015 12:03 PM
alphaauto
Jul 26, 2015 04:40 PM
carolinacasper
Jul 22, 2015 04:47 PM
