stumble at cruise speeds
Old Aug 18, 2002 | 05:03 PM
91rs383's Avatar
Question stumble at cruise speeds
problem is with my 383 carbed 91. it has a full msd ignition system w' 6al box. the car idles great, but from around 2200-2800 it has a miss in it that seems to be getting worse. once you get past 2800 or so it revs perfect just like it should. i have had the carb apart twice and put new float bowl, jet block, and bottom plate gaskets in it. i have also had the distributor apart and have everything perfect inside it. has anyone else come across a problem like this?? any and all help would be greatly appreciated. thanks in advance.
brandon
79 Z, 357, pro1 heads, victor jr.intake,
prostars, powerglide, 9" ford w/ 4.86 gear, etc...
best pass to date :10.16@132.72mph
91 rs stroked not sprayed
11.86@115 so far........
Old Aug 18, 2002 | 07:38 PM
MonteSS427's Avatar
Post
My 307 Stroker in my Monte acts the exact same way, started doing it recently. Plugs and wires check OK, distributor and HEI OK, haven't checked carb yet but I haven't touched it in a while so nothing should be changed. Curious as to what it is too...
Edit: It only does it at cruising speeds on the highway. I would probably say 2000-3000 RPM at a constant speed. Speeding up or slowing down will make it stop "missing" and it will run smooth again until a constant speed is once again reached.
| There is no replacement for displacement |
| Soon Future F-Body Owner !
[This message has been edited by MonteSS427 (edited August 18, 2002).]
Old Aug 18, 2002 | 09:54 PM
kmook's Avatar
Advanced Tech Moderator
Post
This question is more suited for a regular tech section. I will move this over to 3rd Gen Tech, Thanks!
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
edman
Mar 13, 2015 09:39 PM
njspder
Middle Atlantic
Mar 5, 2015 05:39 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
ChrisFrez
Nov 30, 2014 08:41 AM
