which studs??
Old Jan 13, 2004 | 04:52 PM
ReptileZ28's Avatar
which studs??
which arp main studs are supposed to be used for a 2 bolt lt1? my problem is the sbc studs with the windage tray studs not only comes with too many long studs, the studs are not even long enough to hold the windage tray. i called arp and the said i have to order 3 extra studs from a chevy 400 kit with a windage tray but they have sold me the wrong studs twice so far and i want to be sure this time.
thanks
mike
Old Jan 14, 2004 | 06:47 AM
Smoke T/A's Avatar
True you will have to get some longer studs if you want ot retain the stock windage tray. There is not an ARP # for the right kit for lt1.
Joe
Old Jan 14, 2004 | 12:33 PM
ReptileZ28's Avatar
is it ok not to use the windage tray?
thanks for the reply
-mike
Old Jan 14, 2004 | 03:26 PM
Lonnie Pavtis's Avatar
You can eliminate the windage tray if you plan to use an aftermarket pan with an integral tray.
If you eliminate the tray with a stock pan, you will likely have the oil pressure problems/losses as mentioned in other recent posts.
Old Jan 14, 2004 | 04:51 PM
SStrokerAce's Avatar
Yeah I would suggest a Canton pan with just the stud kit to keep it all simple. Canton makes a dam good pan if you have the budget for it.
Bret
Old Jan 14, 2004 | 09:39 PM
ReptileZ28's Avatar
well, i guess i'll have to buy the 400 studs since i have no budget left for a new pan. Thanks for the help
-mike
13qtr
Oct 28, 2016 08:11 PM
karpetcm
Sep 15, 2015 11:07 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
