Strokers and emissions
Old Apr 22, 2003 | 08:47 PM
big dave's Avatar
I lost my motor a couple weeks ago and am weighing my options for replacements. Unfortunately I live in one of those states with pretty strict emissions regulations but I would still like to get the best performance I can while staying clean. I'm considering going to either a 383 or 396 while using the same cam (.533in .544ex, 222-230 on a 112) and heads (stage 2 ARE ported factory castings). What I need to know is what affect a stroker will have on emissions...better or worse, and if the cam I'm using now is too small, is there another cam that anyone can recommend that will improve performance while still passing the sniffer test. Is it worth the effort to increase cubic inches without increasing cam size? Are there worthwhile gains to be found? Are there any cons when considering a 396 over a 383? Thanks for any help/info you guys can give.
Old Apr 23, 2003 | 06:30 PM
Mindgame's Avatar
Stroke the engine and leave the same cam.... it won't make much more hp but it will make a good deal more torque. You'll need head porting and a cam to extend the rpm and make your hp.
Emissions.... well I don't really know for sure but it seems to me that having a larger stroke in itself doesn't change a whole lot. More compression will make for more hydrocarbon output but the combustion chamber is still the same. If you improve the quench height, that might have a tendency to improve things a bit emissions-wise. Then there's the air/fuel ratio... so there a lot more to running clean....... well I should say that the things that really matter are not necessarily tied in with the increase in stroke. I'd say it plays a minimal part.
-Mindgame
Old Apr 23, 2003 | 06:48 PM
Jimmy17's Avatar
more compression puts out more hydrocarbons?
you mean nitrogen oxides or did i miss something?
Old Apr 23, 2003 | 07:07 PM
Josh-'04 GTO's Avatar
I don' t think that is the case...I think Jimmy hit the nail on the head.
In any event, I went with the stroker and passed Mass. emissions with no problems.
Old Apr 23, 2003 | 09:02 PM
Mindgame's Avatar
From an article on the LS6:
The LS6 combustion chamber is quite different from that in LS1 heads. The compression ratio (CR) gains four-tenths of a point to 10.5:1, but getting there wasn't easy. A CR increase has a hydrocarbons (HC) exhaust penalty, but GM wanted the payoff: more power, increased thermal efficiency and better fuel economy. The addition of small, auxiliary, catalytic converters (engineers call them "pre-catalyst" or "pup cats") required for the Corvette to meet LEV standard also allowed the engine the small increase in HC from the high compression.
Maybe GM is wrong but I couldn't find anything on the subject online..... just stuff on diesels.
-Mindgame
Old Apr 23, 2003 | 09:25 PM
big dave's Avatar
Thanks for the replies. I really would prefer to install the larger cam when I put the new motor together but really don't want to go through the problems I did last year with the emissions. I would hate to spend all that money on the upgraded parts for the motor without being able to see the added benefits of the extra cubic inches. If it were easier to change the cams in the lt1s it really wouldn't be much of a problem.
Old Apr 23, 2003 | 10:29 PM
Jimmy17's Avatar
-Mindgame
according to those PR statements (for example) the viper v10 engine is close kin to formula one
...now i'm a big fan of domestic pushrod engines but uh...... formula one..... sorry, lol
also i think we all know gaining .4 compression does not take huge development and research.... just a minute or two on a milling machine
still i'd like to know more about if it just spits out nasty NOx compounds or anything else
Old Apr 24, 2003 | 01:48 AM
Dr.Mudge's Avatar
More cubes will clean up the cam a bit, but dont bank on putting a monster cam in and passing.
Old Apr 24, 2003 | 03:00 AM
SStrokerAce's Avatar
Here is my guess,
Going to say a 230/240 cam up from the 220/230 and putting it on a 114 LSA so you tighten up the overlap should be o.k. on a 383. It's just a guess but cubes always eat up runner volume and duration.
Bret
Old Apr 24, 2003 | 06:39 AM
-Mindgame
That quote wasn't from GM...but rather GMHTP. BIG difference. Good possibility of the author making an error there. I know for a fact the NOx emissions rise due to the increased cylinder temp/pressures of a higher compression ratio. Maybe someone else has some more info on this?
Old Apr 24, 2003 | 02:25 PM
Greed4Speed's Avatar
Just judging by that article and how they "cleaned" it up with another set of cats points to NOx. That is the purpose of catalytic converters, to clean up the NOx emissions. They may have also squeaked by under some loop hole allowing a little higher HC for less NOx. The EPA is full of illogical concepts like that. Ex. emissions trading
Old Apr 24, 2003 | 03:38 PM
To my knowledge, contemporary catalytic convertors contain integrated beds that can promote both reduction (NOx -> N + O) reactions and oxidation (CO->CO2, HC->CO2 + H2O) reactions. You would have to find out if the "pup" pre-convertors are for reduction or oxidation. Logically, you would put the reduction convertor in front, so that the liberated O2 could be used in the main cat to oxidize CO and HC.
Old Apr 24, 2003 | 03:52 PM
Mr. Z28 73/97's Avatar
I've got a stock shortblock
Hey Big Dave I've got a stock shortblock for sale from a 97 SS for $550 if you're interested in getting your car back on the road right away. Call Dale 301-333-8094 or 301-526-4605, sorry to hera she broke, what went?
Old Apr 24, 2003 | 04:58 PM
Mindgame's Avatar
Well Josh,
If you want to be technical... it was actually McMullun Argus Publishing Inc.. This particular publication happens to be "Super Chevy" magazine which I bought just for the LS6 article... although I'm sure other publications ran the article.
Anyhow, considering the fact that the author of this article interviewed and quoted head engineer John Juriga, cylinder head designer Ron Sperry and a few others.... I'd say that he was most likely paraphrasing the information he had gathered. Maybe you know for sure??
And there's always a "possibility" for anything.
-Mindgame
Old Apr 24, 2003 | 05:02 PM
Mindgame's Avatar
Actually, when you know what they did to the combustion chamber to gain that .4 point of compression, you'll understand that there was a bit more involved than just "milling the head". What I gather, is that the change in combustion chamber shape also changed the bowl and port of the head. I believe Chuck has posted on the differences in another thread... maybe you can strike up a debate there.
-Mindgame
