Stroker possibilities with a 400 block?
Old Jun 30, 2003 | 10:21 PM
  #31
SStrokerAce's Avatar
Clearancing is not that big of a concern. It's the machine work to get everything where it needs to be on a stock block. There is aHP and reliabilty in a stock block and what Mindgame says is true, it's going to cost time and money to get a stock block close and in the end it's going to be less block for the same money.
Just stay NA with that thing and you should be o.k.
Bret
Old Jul 1, 2003 | 11:04 AM
  #32
Mindgame's Avatar
Originally posted by DarthIROC
Well if I bought a world products block or something, would it still need to be clearanced or could I drop a 4.00 in crank in there as is?
I mentioned it in the other thread but the Motown is pretty well clearanced as it is (bores and pan rails). You'll just need a little rub here and there for the 4-inch crank. Cam position is still the same height, so you need to let the cam grinder know what the cam is going in. A little clearancing of the rods will also help.
It's just alot easier with the Motown block. Not to mention the block is alot stronger. Having looked at a few of these since they came out... Mitchell really built this block for the guys who wanna build long stroke strokers (3.875 and up). I'd take it any day over a Bow-tie for this type of build...... and yeah the Iron Eagle and Rocket are even nicer but they will cost you a bit more dinero to put together.
-Mindgame
Old Jul 1, 2003 | 02:14 PM
  #33
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I havent really decided yet what Im gonna do, but I would really like to make a huge displacent SMC. I may be getting a new job with a friend of mines parent company makin alot more cash than I do now so we'll see what happens.
Im going to a huge swap meet in Iola WI, in a few days. Its advertised as like the 3rd largest meet in the US. Maybe Ill come up with something there. I would imigine a meet that big would offer some cool aftermrket stuff. maybe Ill come across a used Dart block or something.
Old Jul 3, 2003 | 03:42 PM
  #34
GPZ406's Avatar
Originally posted by Mr. Z28 73/97
One thing to add, get a Motown or Bowtie block while you're at it because by the time you spend the money to add splayed caps and all the machine work you will only be a few hundred shy of the price of one of these much stronger blocks. Otherwise you will soon be rebuilding especially the guy who wants to add a 200 shot.
You just talked me down from the ledge.I have a 2-bolt 509 production block,4.155 bore,splayed cap,and was going to try a 200 shot this sat. I`ve used a 150 shot a few times and it`s still in one piece.Do you guys think it will survive this level of nitrous for a while?
FWIW,I`ve had this engine apart and found that the machine shop did`nt use torque plates when honing the block.How? There were carbon spots at every head bolt hole about 3/8" wide and 2" long in the cylinders.Thin walls will MOVE!
RUENUF
Mar 13, 2016 03:39 PM
Drtryder
Apr 22, 2015 04:17 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
