Stainless vs chromemoly rockers
Old Apr 13, 2004 | 09:43 AM
  #16
DougJ's Avatar
mine is a solid roller . have you done deflection tests between the two? I bet its not a big difference between the two when used with the typical 600 pound on the nose sr spring. The deflection in the pushrods would be of far greater concern to me.
if I had deeper pockets I would have gone for the stainless Crowers or Comps but......
Old Apr 13, 2004 | 04:40 PM
  #17
SStrokerAce's Avatar
True the pushrod will deflect more but the rocker is still going to deflect at 600lbs over the nose. I really stop using the Pro Mags at around 400lbs over the nose. Even then if you decrease the delfection in the system you can see 10-20hp, so I would imagine that if you had stiff pushrods and stiffere rockers you could find some more power.
Now if you look at the LS1 motors, those guys are gaining 10-15hp over the stock rockers on setups where 300lbs over the nose. It's not just the roller tip reducing friction but going all out and getting that delfection out of the stock rocker. Then again they cna also get 410-450rwhp with stock ports in their heads with HR cams, it's going to be cool to see a well done SR in one of those things.
Bret
Old Apr 13, 2004 | 05:00 PM
  #18
jonaddis84's Avatar
Looks like I can get the hitechs for $339, so I might just use those, hell, cant hurt, and Id be kinda special, not many people use them. Plus after what Bret said about 15-20hp possiblilty in decreasing deflection in the rocker, maybe not over promags, but over other types such as aluminum or stamped.
Who seems to make the best pushrod these days, still 5/16 though. I liked my trick flows since they were the only part to survive in my engine!
Old Apr 13, 2004 | 06:08 PM
  #19
Mindgame's Avatar
If you have a good engine simulator, vary the stiffness of the rocker arms on a 6500+ aggressive roller engine and notice what it does to hp curves. I'm not sure if all simulators have this option.
Which engine simulation programs (affordable for the avg. car guy, aka under $500) are you able to do this in? I'd be skeptical of any cheap simulation software that claims to be accurate here.
Well, if you just have to spend the extra money have at it.
"Best pushrod" is all a matter of preference though. Most here are going to be Comp fans but my pushrod money goes to Manton. Their 11/32 to 5/16 taper pushrods are as much pushrod as you'll ever need for a SR street car.
-Mindgame
Old Apr 13, 2004 | 06:29 PM
  #20
Mindgame's Avatar
Bret
Just wait a couple more months and you'll see a certain 02 Z06 that might just surprise you Bret.
-Mindgame
Old Apr 13, 2004 | 06:57 PM
  #21
Not much good engine software below $500 that's worth anything. Any program that does is not going to be close to a what a spintron will tell you.
As for pushrods I'm more of a Smith Brothers fan than anything. Hell a 7/16 tappered pushrod is more than most street guys need.
As for that 02 ZO6, I honestly think that 475-480rwhp is doable with stock LS6 castings. 450rwhp has already been done with a LS1 casting and a HR cam, dam thing is not something I would consider driveable for any period of time, but you could cruise it around. The good thing about the LS1 motor is that the stock LS1 heads which are the worst of the bunch flow what a bunch of ported LT1 castings flow, finally guys like Ai and Lloyd are getting more flow than them, but the LS6 castings are really impressive for a as cast OEM stock part. 260cfm and enough camshaft should make a ton of HP. The real trick is to make the thing a real street car. There is a good amount of power between a car that needs a vacuum canister to work the brakes and one that goes up hills on the highway in 6th gear with 3.73's in it at 60mph.
Bret
Old Apr 13, 2004 | 08:27 PM
  #22
OldSStroker's Avatar
-Mindgame
EA Pro, which costs about $469 claims to have this ability. The online users manual, Valvetrain Dynamics Menu pg 47 (Adobe pg 53) has the input.
Like any software, GIGO applies. With any simulation software the more knowledgeable the user, the more useful the output information. But maybe I'm preaching to the choir here, MG.
Old Apr 13, 2004 | 08:28 PM
  #23
Mindgame's Avatar
Exactly where I was coming from.
Ever use Manton? Terry builds pushrods for alot of fast guys... Mike Moran, Gene Fulton, Leonard... it's a long list. Best thing about Terry, besides the fact that he builds the strongest pushrods in the industry, is that he's super quick on custom lengths. Not to mention, very personable and a good all round business man. Give him a call sometime.
Bret
The engine I'm putting together is going to be built around the new AFR head. This will be a 422 ci stroker and we're shooting for a very streetable 500rwhp..... we'll seeeeeee!
-Mindgame
Old Apr 14, 2004 | 01:54 AM
  #24
Steve in Seattle's Avatar
[B]Most here are going to be Comp fans but my pushrod money goes to Manton. Their 11/32 to 5/16 taper pushrods are as much pushrod as you'll ever need for a SR street car.
wow, cool stuff there. (www.mantonpushrods.com)... but at $400 a set I nearly crapped my pants.
Guess it comes down to buying quality once, instead of "good enough" twice.
hmmm... slap those on some Jesel shaft rockers, Brodix heads, Brodix block, etc.... its no wonder NHRA professionals need at least 20k per engine.
What we need to do is get a petition going to have GM build 4140 chromoly tapered pushrods in all future engines. That'll bring the costs down.
Old Apr 14, 2004 | 01:38 PM
  #25
Mikey 97Z M6's Avatar
I just found it interesting that nobody mentioned Crower SS rockers. Fully re-buildable and you can buy individual parts for them like roller bearings, tips, pins etc... Nice pieces.
Mike
Old Apr 14, 2004 | 05:31 PM
  #26
DougJ's Avatar
Talking
Mikey,
you didnt read close enough. I mentioned the Crowers.
Doug
Old Apr 14, 2004 | 09:54 PM
  #27
I just saw that, my bad.
Mike
Old Apr 15, 2004 | 12:24 AM
  #28
OneFlyn95z28's Avatar
I ran a set of Crowers for years on a solid roller cam motor shifting at 8,500. no problems.
In the past 6 years I have went through 3 sets of the Comp Cams crap and lost one cam shaft altogether..
I just picked up a set of those new Cat Stainless rockers for $149 to my door. Half of what I have been paying for the Comps.
OH YEAH Comp wants about $200 a set to "Rebuild" the damn things
Old Apr 15, 2004 | 01:25 AM
  #29
Hmmm... just did a little window shopping:
$240 C.A.T. (SS stud)
$240 Comp Cams Pro Magnum (Chromoly stud)
$340 Comp Cams High Tech (SS stud)
$440 Crower (SS stud)
$600 Probe Industries (Aluminum/Steel shaft)
$695 Jesel Sportsman SS (SS shaft)
$890 T&D Machining (Alluminum/steel shaft)
And upwards they go to ~$2000.
Everyone above is rebuildable, but CompCams won't sell parts separately.
Hey Ellis, where did you score the CAT rockers so cheap?
Old Apr 15, 2004 | 01:51 AM
  #30
nevermind... I think I found 'em
