sorry to post here but ls1 ?
Old Jun 8, 2004 | 06:46 PM
FLIPPINZ28's Avatar
hey i posted in the ls1 forum nobody knew but will a 99 engine harness work right with a 2001 engine and computer i know the 99 have egr and mine doesnt does anybody think this will work thanks alot kenny
Old Jun 8, 2004 | 10:10 PM
Steve in Seattle's Avatar
I dunno. You may want to check on ww.LS1tech.com
Old Jun 10, 2004 | 01:55 PM
Taspeed's Avatar
As long as you have the right pcm m6 or a4, and you have a copy of edit (or have someone edit it). You will need to kill the egr codes. I think the fuel tables are ever so slightly different, but it will function if that is what you are after.
Rich
Old Jun 10, 2004 | 03:30 PM
FLIPPINZ28's Avatar
will i still have egr codes when my computer is a 2001 already my engine is a 2001 aswell. so the harness will plug in and work right.i thought the computer controlled the fuel.
Old Jun 10, 2004 | 04:21 PM
Taspeed's Avatar
For all practical purposes the answer to all your questions are yes. and the pcm does controll the fuel, but its in the 20 some odd fuel tables programmed into it It will be fine.
Old Jun 10, 2004 | 06:09 PM
FLIPPINZ28's Avatar
thanks so much for that response i found a harness for 98 for 100 bucks great thanks alot kenny
