Solid Roller Springs w/ Hydraulic roller cam?
Old Oct 4, 2005 | 06:24 PM
Sneakin Deacon's Avatar
i have 977 springs, but am going hydraulic roller, just wondering what exactly the differences of solid roller springs and hyd. roller springs are. as far as i can tell...in comparison to the 950's, i can only see the seat pressure being the significant differance at the open seat pressure #'s. can i run the 977's without issue, or should i go to a hydraulic spring?
Old Oct 5, 2005 | 05:35 PM
SStrokerAce's Avatar
Re: Solid Roller Springs w/ Hydraulic roller cam?
The 977's will work on a hyd roller been there done that. I wouldn't downgrade the springs any less than that.
Bret
Old Oct 7, 2005 | 04:06 AM
Victory Racing's Avatar
Agreed, I use the 977's fairly often.
Old Oct 8, 2005 | 06:32 AM
HiTech5's Avatar
Comp recommends the 987 springs for their more aggressive HR cams. I have found them to be less than adequate after a short period of time.
I like the 977 springs and recommend installing them slightly higher so to yield approximately 150 lb seat pressure.
www.geocities.com/dzperf
Old Oct 8, 2005 | 09:29 AM
thanks guys, going to run this with some morel's and probably run some more lift aswell. just have to worry about piston/valve clearance now with .615 lift
Old Oct 8, 2005 | 03:00 PM
The lift isin't the problem with P to V it's valve events that count.
I agree with HiTech... the 987's are far from enough valve spring to do the job.
Bret
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
