solid roller lifters?
Old Oct 6, 2002 | 12:54 AM
AHARTZ28's Avatar
i was told by someone today to get into the habit of changeing solid roller lifters every 5-6k now i have never heard of this before i could see it if you ran oil restrictors..
i know i have to adjust the backlash and record the cold backlash to know if a roller is wearing.. anyone had to do this?
Old Oct 6, 2002 | 04:21 AM
kmook's Avatar
Advanced Tech Moderator
Hey Ryan,
They should last a lot longer than that, i could see restrictors maybe reducing their life, but still i would think that they would last longer than 5-6k miles.
Old Oct 6, 2002 | 12:49 PM
Jason Short's Avatar
They will go 20k miles for the most part in street applications.
Jason
Old Oct 6, 2002 | 08:11 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Question 20K miles??????
wow, well 3 of my comp cams solid roler lifters died only after 5000 miles! now the motor is getting torn down for new bearings and rings.
who makes a rebuildable solid roller lifter? i will do anything to keep my monster a street car driver, it lives on the street and has fun at the track.
does jesel make one? i was told that they do.
Old Oct 6, 2002 | 08:16 PM
jimlab's Avatar
I'll quote Mark...
"Jim, don't believe everything you read. If I felt the engine required a different approach, lifter or restrictor I would have done so. At present it has an .080" restrictor and 75-80 lbs. of pressure at will (zero bypass). I have used CompCams Endure X series as well, which grooves the lifter and not the bore; both the Endure X and Crower Severe Duty (what you're running) are fantastic lifters (hence the price tag they carry). I would estimate 25k out of the lifters without any question of duty. The key here is solid lifters don't like stop and go traffic in a low oil environment; many use a .030-.050" restrictor for increased power (less windage) and in a long-idle condition, it can start starving the lifter bores. On the same token, we have bushed your lifter bores for perfect concentricnticty. I myself have run solid roller lifter since 1997 without a single failure as of yet."
Old Oct 6, 2002 | 08:30 PM
taner's Avatar
jim? do you drive your car on the street alot?
would you recommend a particular solid roller lifter? i need to decide asap so i can take the appropriate action. thanks!
taner
Old Oct 6, 2002 | 08:36 PM
jimlab's Avatar
I haven't had the pleasure of driving my engine yet, unfortunately it's still in California.
I highly recommend the Crower lifters, but they are pricey. As Mark said, the Comp Cams Endure-X solid roller lifters are also excellent.
Old Oct 6, 2002 | 08:53 PM
taner, were you running the Endure X lifter?
Jason
taner's Avatar
jimlab, another question for you....
do you know if either of these are rebuildable?
Old Oct 6, 2002 | 08:59 PM
jimlab's Avatar
Re: jimlab, another question for you....
End-user rebuildable or factory rebuildable? Crower can rebuild the lifters for you, I believe, but they're as close to bulletproof as you'll find, probably. I can't speak for Comp Cams, but I don't see why they couldn't rebuild theirs also.
Old Oct 6, 2002 | 09:10 PM
taner's Avatar
are these anywhere online to checkout?
unsure of what lifter's they are. i will be finding out tomorrow
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
