Solid roller cam maintenance
Old Jun 26, 2003 | 12:12 AM
  #46
jimlab's Avatar
Originally posted by Mindgame
Yep, a pressurized source is the way. Using a -12 line from the cooler is the setup I'm using.
-12 to feed the valve covers? Do you have any pictures?
Old Jun 26, 2003 | 03:05 AM
  #47
WS6 TA's Avatar
Originally posted by jimlab
2. Buy a spring pressure tester and check the springs for peace of mind before I install the engine. It'd be easier to work on out of the car, so I can find out if the springs have lost tension during the time the engine was sitting.
Quick note here, make sure it's on a good stand while doing this. I just got stuck lifting a 500ci caddy off a friend of mine that dumped the engine while messing with the valve springs while on an engine stand. 600# landing in your lap is not good (almost as bad as deciding that you could just lift it off him, sometimes it's nice to be big...)
Old Jun 26, 2003 | 07:27 PM
  #48
Mindgame's Avatar
Jimbo,
You've got mail.
-Mindgame
dfarr67
Apr 10, 2015 07:44 PM
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Wicked
Jul 25, 2002 04:19 PM
Ed95Pont
Jul 23, 2002 08:26 AM
