Siamesed Bores??
Old Aug 18, 2004 | 08:14 PM
mycarisfasterthanyours's Avatar
Siamesed Bores??
What exactly is meant by siamesed bores, and what are the advantages/disadvantages?
Old Aug 18, 2004 | 08:54 PM
OldSStroker's Avatar
Re: Siamesed Bores??
With Siamesed bores, there is no water jacket where the bores are closest together; the casting is continuous and there is a solid wall between adjacent bores. They are "conjoined". Non-Siamesed bores have water completely around each cylinder wall.
FWIW: "Siamesed" comes from "Siamese twins". The first pair of conjoined twins of any prominence (c. 1811) were Chang and Eng who were joined at the abdomen and shared a liver. They were originally from Siam, now known as Thailand, hence the name. ("Thailandese twins" is too hard to say. )
Siamesed bores are conjoined and are therefore stronger, especially for large bores, like 4.125 and above in a SBC with 4.400 center to center bore distance. The conjoined bores distort less so they can theoretically support more power. The downside is that cooling water doesn't get to that conjoined area so more heat is retained in the cylinder walls, and perhaps distortion could be more because the wall thickness and support varies greatly around the bore. IMO, for large bore-to-bore spacing ratios (like 4.125+ in a SBC), conjoined bores are the best choice.
Old Aug 18, 2004 | 09:25 PM
Thanks, always been curious.
Old Aug 18, 2004 | 11:25 PM
kmook's Avatar
Advanced Tech Moderator
Your wealth of knowledge never ceases to amaze me.
Old Aug 19, 2004 | 07:06 AM
Google is my friend.
http://www.google.com/search?as_q=&n...h=&safe=images
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
