Shop wants to use 30 thousandths clearance
Old Jan 22, 2005 | 03:53 PM
  #16
SStrokerAce's Avatar
Re: Shop wants to use 30 thousandths clearance
Originally Posted by racer7088
I can tell you from experience that if they aren't linehoning for instance a LOT of guys run that much since the bores aren't all in line basically too but .003 isn't gonna hurt anything probably but low rpm idle oil pressure when the engine is hot.
Line honing is a big point. You can't run a tight clearance on a motor if the main journals in the block are on both sides of the tolerance. That +/- .0005 tolerance can make one journal .001 bigger than another. If you don't try and keep the journals within a few tenths (.0001) then bearing clearance will be all over the map. So you have to open them up.
Bret
Old Jan 24, 2005 | 07:24 PM
  #17
Villain70's Avatar
3 thousands clearance is pretty normal for a performance oriented engine. It has a lot to do with how much break in time it will see. If its a drag only motor where it would get maybe 30 minutes break in, I would go with the loose clearances. If its a long time streeter, then go a little tighter. Oil viscosity and pressure also will play a role in this. My theory is that you are better a little on the loose side than too tight.
Old Mar 15, 2005 | 12:38 AM
  #18
Found a really good rule the other day that works perfect IMHO....
.0011 x main journal diameter = clearance. Add a little for the back cap on a chevy and you are set.
Bret
Old Mar 16, 2005 | 09:02 AM
  #19
Gripenfelter's Avatar
Thanx again guys. I was looking at running Mobil 1 this year.
Old Mar 18, 2005 | 09:35 AM
  #20
onefastgta's Avatar
Mine are at .0015-.0018 on the rods and mains and .0025 on #5, and my oil pressure is 30-35 hot at idle. No problems here, but it is more of a street-strip car, and I don't plan on pulling the motor each winter either. It's your motor, build it how you want it. I also run mobil synthetic 5-30 and 10-30 depending on the temp outside.
Old Mar 18, 2005 | 09:48 AM
  #21
So a bit tighter than what they want to use would be better?
I want to use Mobil 1.
Old Mar 18, 2005 | 08:30 PM
  #22
lt4 fd's Avatar
From what ive read in a couple places mobil oil is actually a little thinner than the exact rating they give. ex. thier 30 wts are more in the 20's
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
Z Power
Sep 19, 2015 11:19 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
