Shift forks on a (LT1) T56?
Old Aug 11, 2002 | 02:21 AM
Ponyhntr's Avatar
Post Shift forks on a (LT1) T56?
How hard is it to change a shift fork in a T56? Is there any special tools needed to do the job? I just bent the 3-4 fork tonight, and I was considering doing it myself. I have rebuilt several T5's but have never had a T56 apart. Is there any tricks that I would like to know about? Thanks for all your help guys. Moderators- I'm pretty sure this is in the right section, (as the title says driveline rebuilds), but if it's not, go ahead and move it. Thanks!!
Josh
96 Z28
12.700 @ 111.5
Old Aug 11, 2002 | 08:44 AM
kmook's Avatar
Advanced Tech Moderator
Post
Nah your your in the forum
Sorry I dont know much about t56 rebuilds though...
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
Old Aug 11, 2002 | 10:37 AM
OneFlyn95z28's Avatar
Lightbulb
If you can do a T-5 then a T-56 will be ok for you. hardest part is getting shifter parts all lined back up after that i would say getting the tail housing back on. Trick to tail housing is greesing the bearings with trans gel
The new steel 3-4 shift fork is a very nice part. Cheap at under $50
Good luck!
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
Old Aug 11, 2002 | 09:01 PM
Ponyhntr's Avatar
Post
Ellis- you said the NEW steel 3-4 shift fork is nice- did they come out with an upgrade to the stock one or something? Or is it not a GM part? I can get GM parts for cost, so if it's already under $50, it shouldn't cost me much at all! So there are not any special tools or anything to disassemble it? I was looking in my repair manual (GM), but it doesn't go into disassembly of the trannys-just R&R. Thanks for your help.
Josh
96 Z28
Old Aug 11, 2002 | 09:12 PM
jay christopher's Avatar
Post
d+d trans sells the steel fork. they also sell a repair manual for t56s.id suggest it if you are a first timer.its not bad,but there is alot of parts in the first part of the case and you do not want to mix them up!!! the only thing i forsee is getting off the 5/6drive gear off the main shaft, it is pressed on and you need a puller to get it off. you do have to disassemble the whole trans to get to the forks.good luck, jay
Old Aug 11, 2002 | 10:11 PM
Ponyhntr's Avatar
Post
Thanks for the heads up, Jay. I will give D&D a call in the morning.
Josh
96 Z28
Jason Short
Jan 19, 2015 06:34 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
cmdeshon
Dec 27, 2014 10:06 AM
Nostang 96z
Sep 14, 2002 08:22 PM
