sharp edge orifice sizes and cfm ratings
Old Jun 19, 2005 | 05:17 PM
sheppard00's Avatar
are the sizes and cfm rating's on this website good
http://www.diyporting.com/flowbench.html
I need to know the cfm for these size orifices
3/4
1/2
1/8
7/8
Old Jun 20, 2005 | 08:08 AM
Dryseals's Avatar
Re: sharp edge orifice sizes and cfm ratings
It's not quite thate easy to say a 3/4" orifice has X cfm. There are to many variables left wide open. I suspect you are trying to build a flow bench, novel idea. Getting a home made flow bench to flow accurately is not that easy without all the correct instrumentation. Here is a link for some calcs related to flow.
http://fire.nist.gov/bfrlpubs/fire97/PDF/f97087.pdf
You can build a unit that will tell you if you flow has increased, but without a constant temperature, pressure and humidity, the results could be missleading.
HectorM52
Jul 30, 2017 11:46 AM
CARiD
Jul 7, 2015 08:19 AM
4586
Apr 27, 2015 06:08 AM
ShwaZedder
Apr 9, 2015 06:33 AM
