Shaft mount roller rockers
Old Oct 15, 2006 | 03:17 PM
InsaneIROC's Avatar
Will shaft mount roller rockers clear center bolt style valve covers.
Old Oct 15, 2006 | 04:27 PM
cnorton's Avatar
Re: Shaft mount roller rockers
I'm using a T&D shaft-mount rocker system with fabricated, sheet-metal, center-bolt covers so I'm sure that the center-bolts clear the mechanism. If you use other-than-stock rocker ratios be careful to check all pushrod clearances. Both the heads and the valve covers required clearancing to provide room for the 3/8 pushrods with 1.8 intake and 1.6 exhaust ratios.
c
HarleyZ28
Oct 5, 2015 06:23 AM
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
