Shaft mount roller rockers
Re: Shaft mount roller rockers
I'm using a T&D shaft-mount rocker system with fabricated, sheet-metal, center-bolt covers so I'm sure that the center-bolts clear the mechanism. If you use other-than-stock rocker ratios be careful to check all pushrod clearances. Both the heads and the valve covers required clearancing to provide room for the 3/8 pushrods with 1.8 intake and 1.6 exhaust ratios.
c
c
