SBC head converted to LT1 head?
Old Apr 16, 2003 | 10:22 PM
MLBurns's Avatar
Has anyone successfully done this? Myself and a friend that is a machinist think it is possible. We are sure we will have to use a LT4 intake for the larger runners, we also talked about making a crossover pipe on the intake instead of having it on the back of the heads. The bolt holes on the intake are different, but a little welding and drilling will fix that. The coolant holes need to be enlarged to match the block. Are we crazy or is this possible?
Old Apr 16, 2003 | 11:04 PM
Abdullah's Avatar
it is possible, becuase i know that Matt Antonelli from North Jersey Racing told he can convert Brodix heads to LT1 style and i guess he will do what you mentoined to convert the Brodix heads to LT1 reverse cooling. but maybe you still need to drill the 2 holes at the back of the heads.
Old Apr 17, 2003 | 04:46 AM
SStrokerAce's Avatar
Yeah, but you are kicking youself in the nuts if you are going to run a LT4 intake. A single plane or a sheetmetal is really worth it.
It's not to hard to do actually.
Drop me a e-mail.
Bret
Old Apr 17, 2003 | 05:19 PM
Mindgame's Avatar
Nah, 665 hp/557 lbs-ft was the last call on my engine with everything finally in place. Not bad for a factory LT4 intake modded out the wazoo. Buy a custom and you're looking at ~$2500. I bought the LT4 for $50 at a swap meet and spent some $600 in porting and machining to make it work on a 15* head. Worked-over... the intake flows some ~330cfm so I don't think it's hindering things much at all. Yeah, a longer runner would have been nice but I'm not looking back at this point.
And if Jon is reading this (he asked me about the intake I'm using in another thread but never heard back from him)... the RR Edelbrock intakes won't work on a 15* head. You need an intake specific to 18* heads and a little modification.
A departure from the normal stuff most people are familiar with... unless you do the race thing.
-Mindgame
Old Apr 17, 2003 | 09:02 PM
FASTFATBOY's Avatar
I am having a set of Pro-Action 235's converted as we speak, yes the intake side needs some changes, also the oil return holes have to be re-worked, I sent an old LT1 head the West Coast cylinder head to have all of the stuff copied, Richard is also modding a LT4 intake to go with it. Mindgame can I have some specs on the monster you built?? I am doing a solid roller 383 hoping for 600/620 FWHP.
David
Old Apr 17, 2003 | 09:26 PM
Fast Caddie's Avatar
Aye, ol' Mindgame has a very bad ride. Although he has yet to hook us up with some pictures, video, fine details...(hint hint )...
Old Apr 18, 2003 | 12:18 AM
Mindgame's Avatar
Details will be coming but.... videos are a maybe. Right now my main concern is getting the car back together and getting it on a chassis dyno. Then we can tweak a few things, run her at the track and make some more adjustments.
Al in all, we're probably looking at 7k shifts and pump gas. Gotta get a rear-end under the car too. It's on the way. Other than that, she's about ready for blast off.
-Mindgame
Old Apr 18, 2003 | 09:31 AM
Nice!
Mindgame
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
