sb2.2 heads
Old Jan 10, 2006 | 03:28 PM
  #16
marshall93z's Avatar
Re: sb2.2 heads
Exactly!
Old Jan 10, 2006 | 09:28 PM
  #17
Mindgame's Avatar
Re: sb2.2 heads
10.9,
You're absolutely right, a 457 ci sb2.2 headed race car should make 1000+ hp NA with cubic dollars, 16.0+ compression and the right parts. But... as the other guys here have so kindly pointed out (I think they all know me pretty well now )..... this isn't a RACE car, it's a driver.
As a matter of fact I've taken a whole new direction with the car. The setup will be much more "Road Racer" than "Drag Racer" this go round. Just something different for me... not that I plan on being the next Silver State winner or anything but that doesn't mean I won't try it at least once before I die.
Frankly, like alot of you guys, I just like these 4th gens. Kinda like the Mako sharks of the car world. Don't see myself getting rid of this one any time soon.
-Mindgame
Old Jan 10, 2006 | 09:39 PM
  #18
10.90streetcar's Avatar
Re: sb2.2 heads
Thanks Mindgame. Just thought those HP #s were kinnda week for those flow #s and Cubic inches.. Im in the precess of building an sb2.2 Race Motor. It will be a 4.165 bore with a 4" crank ( 436ci) with 15.4 CR. Heads are NASCAR "Take Off Heads" that only flow 380 cfm @ .600
Old Jan 10, 2006 | 09:51 PM
  #19
Mindgame's Avatar
Re: sb2.2 heads
Yeah, in race trim the thing should fly.
Just to keep things in perspective here, the cam in the new beast is hardly beastly at all with just 256º @.050.
She'd sing a whole other octave with a bigger stick, but I'm content....... for now.
-Mindgame
Old Jan 10, 2006 | 09:59 PM
  #20
N20Dave's Avatar
Re: sb2.2 heads
MG, those are some killer numbers. Your combo will make a killer street package. I wish I could run mine on pump gas and make that much. Of course that's the difference 60+cfm makes.
10.90 streetcar:
To give you an idea, mine flow 380cfm also and are on a 396ci 4.030" bore motor with a 270/280 .710 lift sr with 13.5-1 and a very short restrictor plate style intake and it's made 740 at the crank so far.
Old Jan 10, 2006 | 10:07 PM
  #21
Re: sb2.2 heads
Heres the Specs on my cam. 280/296 .740/.716 on a 112 LSA.
Why the very short restrictor plate style intake. Also I would think that small bore is also hurting you some as well.
Old Jan 10, 2006 | 11:36 PM
  #22
N20Dave's Avatar
Re: sb2.2 heads
We needed it for hood clearance and got a good deal on it. We didn't feel like shelling out money for a larger cowl hood that will get us tickets plus We've got some coin in custom paint and it's a nitrous motor so I just figured I'd put bigger pills in it
Your larger cam, bigger bore, higher compresion plus better intake should have you in the high 700's low 800's I would think. What do the rest of you guys think?
Old Jan 11, 2006 | 12:26 AM
  #23
SStrokerAce's Avatar
Re: sb2.2 heads
I would hope so!
Bret
Old Jan 11, 2006 | 03:37 AM
  #24
Rob94hawk's Avatar
Re: sb2.2 heads
-Mindgame
So your saying that you shoved a 457ci smallblock in a 4th gen with a stock hood?!?
Got pics?
Old Jan 11, 2006 | 02:26 PM
  #25
Re: sb2.2 heads
I would think my combo should make over 800
Old Jan 11, 2006 | 07:25 PM
  #26
Mindgame's Avatar
Re: sb2.2 heads
700-800 should be cake for a race motor!
I'd personally tear it apart and try again if it made less than 900. While I agree that the sb2.2 is a the best small block head out there, I also believe you need two carbs to really make big hp. When we start going to multiple carbs, my thoughts shift to a splayed valve head designed with that in mind. Of course a sheetmetal intake is a must.
-Mindgame
Old Jan 11, 2006 | 07:26 PM
  #27
Mindgame's Avatar
Re: sb2.2 heads
BTW Rob,
The engine is the same external dimensions as the LT1.
Well, it's a little beefier and has a .300 taller deck but everything fits just like "stock".
-MG
Old Jan 11, 2006 | 07:27 PM
  #28
Re: sb2.2 heads
Too bad there are no awesome splayed valve GM heads... I hear that the ROX head is supposed to be double throw down though.
Old Jan 11, 2006 | 07:30 PM
  #29
Mindgame's Avatar
Re: sb2.2 heads
Bret,
The old 504 made 1000+ with the old GM splayed valvers. If you go to alcohol then you can run the Alan Johnson splayed head. Works ok for Rick Moroso.
-Mindgame
Old Jan 11, 2006 | 07:33 PM
  #30
Re: sb2.2 heads
I've just had a few talented head porters not like those heads AT ALL... hell I couldn't tell you if they were the cats *** or not.... they just require a ton more work than something like a SB2.2, but then again when those didn't exsist the splayed valve was the top dog.
I still remember the sounds of those Intrepid GTP cars back in the day with 365 and 396 splayed valve aluminum small blocks.
Bret
