safety wire
Old Jan 18, 2005 | 09:53 PM
captaindbol's Avatar
safety wire
Any one know the size drill bit needed for safety wire when drilling a bolt head?
Thanks, James
Old Jan 18, 2005 | 10:15 PM
Rob(94Hawk#319)'s Avatar
Re: safety wire
IIRC, safety wire is .032", so a bit bigger than that would probably be good.
Old Jan 18, 2005 | 10:54 PM
Stephen 87 IROC's Avatar
Re: safety wire
Actually it depends on the size of the safety wire. I have some stainless safety wire that's thinner than most mild steel safety wire.
Measure the thickness of the wire and drill the hole slightly larger.
Old Jan 19, 2005 | 05:55 AM
oil pan 4's Avatar
Re: safety wire
common sizes are .020'' .032'' and .040''
I use .020'' on electrical plugs, .032'' on bolts, nuts, AN caps/plugs and .040'' for v-band clamps.
I do a good bit of safety wiring, you have to have a pair of safety wire plyers, you can do it a lot better.
Have you ever safety wired before?
Old Jan 19, 2005 | 07:06 AM
OldSStroker's Avatar
Re: safety wire
Is safe wiring anything like safe sex?
Look near the bottom of page 2578 in McMaster-Carr online catalog:
http://www.mcmaster.com/
search for "pliers twisting". The pics and description should help. Gee, they even have clockwise and counteclockwise directional pliers. I guess in Australia you'd have to use CCW twists. It's a coriolis thing.
Old Jan 19, 2005 | 10:18 AM
Re: safety wire
"Is safety wiring anything like safe sex? "
Maybe, I've never gotten off doing either.
As for the wire help, thanks guys, I've learned a lot. I thought all safety wire was the same size and had never seen any that was'nt stainless. I'e used the wire a few times before but never bothered to mic it or had to drill any holes for that matter. The moser 12 bolt has finally unearthed itself from underneath my parts car and will go in the T/A this weekend. I was thinking about wiring the bottom 2 bolts for my spohn torque arm as they never seemed to stay torqued down. Anyone tryed this before?
James
Old Jan 19, 2005 | 12:11 PM
Z28SORR's Avatar
Re: safety wire
"Summit" amoung others, offers a safety wire drill fixture. So you can drill the nuts and bolts.
Other options are to get new self locking nuts, or use a castellated nut and drill the bolt for a cotter pin.
Old Jan 20, 2005 | 06:08 AM
oil pan 4's Avatar
Re: safety wire
Get the LH and RH twist tools.
You can do RH most all of the time but every now and then you have to do a LH twist.
Sex is fun. Safety wiring is not.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Fatdog2
Feb 13, 2015 08:19 PM
Jan 23, 2015 01:13 PM
