18* Heads and Pistons
Old Jan 15, 2005 | 11:16 PM
97WS6SCharged's Avatar
I was wondering if a set of 18 STDX Brodix heads would work with a set of off the shelf SRP -31cc Blower pistons in a 383 kit? Anyone know for sure?
Old Jan 16, 2005 | 04:17 PM
arnie's Avatar
Re: 18* Heads and Pistons
If you are asking whether or not, it is an 'install blind, with zero issues' question, I'm not your guy.
With that stated, I will add, not knowing your experience/knowledge level, the primary problem I see (ignoring any flow issues), with using (without modifications) pistons intended for a specific head design, on heads with different valve angles, is the piston to valve clearace. This MAY be a mute point, with a piston having a deep wide negative dome the crown. Of course, you would know better than others, what valve lift will be utilized. So, it is you, that will determine whether piston/valve clearance, for the given cam used, warrants checking. If perimeter of negative dome, is a concern, in regards to coming in contact with valve OD, check it.
Old Jan 16, 2005 | 07:42 PM
Denny McLain's Avatar
Arnie
What kind of dope do you smoke?
Old Jan 16, 2005 | 09:25 PM
OneFlyn95z28's Avatar
LMFAO Denny!!!!
LOL Hey there are several off the shelf pistons made now that will work. Most came out in the last few month's.
Old Jan 20, 2005 | 09:36 AM
AdioSS's Avatar
West South Central Moderator
would anybody like to guesstimate on how much closer somebody would be to having clearance problems if they wanted to try putting 18* heads on a stock bottom end LT1?
Old Jan 20, 2005 | 01:37 PM
N20Dave's Avatar
I think the answer here is a custom set. They don't much more than off the shelf pieces and you can have them custom built to your chamber size, valve angle, etc... Give Diamond a call. You'll be supprised at the prices.
Old Jan 20, 2005 | 04:40 PM
SStrokerAce's Avatar
With the size of the valves in a 18 deg head you are going to have little and none P to V clearance on a production Mahle LT1 piston. Time for a Isky Valve relief tool. Then again a 330cfm head probably shouldn't go on a stock bottom end.
18 deg heads for the most part need custom pistons, custom headers and shaft mount rockers. The 18 STDX solve some of these problems but DO A CUSTOM PISTON! Diamond does have a off the shelf 1.250 CH 4.030" Bore piston.
Bret
Old Jan 20, 2005 | 06:04 PM
Dave69Z's Avatar
Bret,
Do you have any experience with the 18X Head? What's your opinion of it and using the Brodix 1800 Manifold converted to EFI?
Dave
Old Jan 20, 2005 | 07:17 PM
Originally Posted by Dave69Z
Bret,
Dave
That Brodix intake is a direct bolt up, and I would expect it's similar to a Super Vic so it would be a good way to go.
The heads are a 10deg face angle like a 23 deg head so maybe something like a Edelbrock 2926 might fit, all depends on port height.
I'm a big fan of Super Vics for any engine when you have the space for a taller intake.
As for the 18X heads, they are going to get you more flow than a 23 deg with standard rockers. A 23deg head that requires shaft mounts might be able to get you more flow. 350-370cfm is possible on top of the line stuff but it's not cheap. The big advantage to a 18X is the valve size, but then again the bore limits the flow potential. The 2.140" valves in the 18X are 53% of the bore size of a LT1, if it's on a 400block then your doing even better. A 18 C is more expensive but there is a lot more flow potential in those heads.
Basically the 18X is a great way to go if you want to stick with Stud Mount Rockers. They are going to get you a ton of flow for the money, I would just want to see them on a 383-400+ cube street motor, or a high RPM 355. Not Nextel Cup high RPM but a healthy drag car with a big stall and a 7,800-8,000rpm shift point.
Bret
Old Jan 20, 2005 | 08:23 PM
got_hp?'s Avatar
thats my next project!
i just finished my forged 383, but like any gearhead, im already planning the next upgrade.
im thinking about getting some brodix 18* std heads with a good port job, and have the 1800 manifold converted for EFI. (unless a vicjr is lower and would work?)
i have to ask you advanced guys though, should i go with a 4bbl tb and a custom elbow like hotrodhawk uses, or to get a wilson-style elbow and bolt-up a large ls1-style tb. i think the wilson style ends up being lower overall, which would be good, as id like to stick with an lt1 ramair hood if possible.
would the new kooks 1 7/8 step headers choke those heads, or would you need a custom set?
Old Jan 20, 2005 | 11:17 PM
Dave69Z's Avatar
Bret
I am currently exploring all my options. I have looked at some of the top of line All Pro and Pro Topline heads and even the Brodix 18 Clones. While they all flow a ton, they all get cost prohibitive pretty quickly compared to the 18X even before you consider that they require shaft setups. Because I really don't want to sink a ton of money into an LT1 as sooner or later I will be going bigger in a traditional SBC. The only reason to stick with the All Pros or Pro Actions would be if I wanted to run in some the LS1Tech based racing series and avoid the 300lb penalty for nonstandard valve angles.
I have a set of bare AFR 227s on the way that I am considering selling to run the Brodix 18X's instead. I can pickup the 18X's complete for $2000 and I figure I would have at least $2400 in the 227s by the time they are completed.
I think the 18X's have a couple of advantages over the 227s in that one the 18 degree valve angle should be a little less shrouded and flow better on the smaller bore even with the larger valve. The 18X's also appear to have much better low and midlift numbers than I would probably get out of the 227s. Additionally the intake bolt holes on the head don't have to be modified for the traditional SBC intake bolt pattern when converting to a single plane. And although I have heard you could order the AFR 210/220/227 with the bolt pattern already machined.....AFR told me that I could not when I ordered the 227s.
Looking around I have found that Hedman sells a 1 7/8" spreadport header for fourth gens which would allow me to take advantage of the 18X SP's spread exhaust ports which offer a pretty substantial flow increase over the 18X STD.
I am trying to balance flow and power with cost. I may still get some true 18s (preferably with intake and rockers) if I can find a set for a reasonable price. But then I am back to modifying a production header or going with some Lemons all at additional cost versus the 18X.
I don't mind intake height as I just ordered a 4" Glasstek Hood and the car is pretty well gutted to be on the ragged edge of street/strip.
The heads are being considered for the refreshening of my 392 (.010 Over / 3.875 Stroke) LT1 and I am not too afraid of rpm as that is the reason I recently purchased a FAST system. Although I would like to keep the rpm within reason as I am using Eagles with L19s and a standard weight Cola crank.
I have spoke with Wilson concerning the 4 Barrel Throttle Body versus using an Elbow with a 90mm Throttle Body. They did not think there would be much if any power difference, but did recommend a spacer for use with the Elbow setup.
I'd like to give you a call sometime and get your input if you don't mind. Lloyd gave me your number discuss manifold options with for the 227s when I was giving them more consideration.
Sorry for writing so much...but I think everybody could learn from the discussion and see that there are a lot of different things to consider besides just changing pistons.
Dave
Old Jan 21, 2005 | 01:40 AM
Dave,
Sounds like you really thought all of this out.
The 18X heads are hands down a good bargin.
If you have talked to Wilson I'm sure you know they charge $650 for the EFI conversion too. It's a lot of work and they do a awesome job but thats a ton for the job at hand.
Bret
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
carl.froehlich
Mar 13, 2015 12:38 AM
pimpss96
Feb 12, 2015 01:28 PM
