QUICK GUYS could this cause my oil pressure to be low?
Old Oct 26, 2003 | 03:26 AM
alex-z28's Avatar
I had low oil pressure lately and saw that I was leaking oil, I didn't check this right away I tought It was time for rebuil for 70k engine. I just went under the car and saw the oil was coming from oil sending unit that's what is right above oil filter on 93s right? Could this cause my low oil pressure, how do I replace it, do I have to drain the oil when removing it, also there is a sleeve and wire how do I disconnect that just pull on it thats where the oil is coming from too. Thanks a lot guys.
Old Oct 26, 2003 | 08:48 AM
kmook's Avatar
Advanced Tech Moderator
This should be posted in LT1 Tech... which it is and already has replies to since that is the correct forum for this question. I will close this thread.
Thanks.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
