Questions about the 383 NEED HELP
Old Aug 1, 2002 | 07:51 PM
Dunn's Avatar
Post Questions about the 383 NEED HELP
My friend needs some help, he has a 1996 Camaro SS and asked me this:
1.If you stroke a 350 but don't bore, how many cubic inches would it be and how much less hp/torque would it lack vs. the full bore of a 383?
2.Can doing a 383 be done without pulling the motor or is there any signifigant $ savings?
3.After stroked, does the redline change or shift points be lowered in the rpm range due to the higher piston speeds at any given rpm vs. stock stroke?
Thanks for the help.
Old Aug 1, 2002 | 09:29 PM
kmook's Avatar
Advanced Tech Moderator
Post
Dunn, These questions are more along the lines of the LT1 Tech forum than Adv Tech. I will move this thread over there for you.
Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
D1SC383LT4
Jan 1, 2016 01:56 PM
cheapchevy
Apr 8, 2015 08:48 PM
transam_388
Mar 15, 2015 11:53 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
