Pump gas motor queston?
Old Jan 4, 2005 | 08:46 PM
Black95Form's Avatar
Looking at building a solid roller nitrous motor that could be filled up with 93 octane and driven on the street once and a great while. Would a 11.7 static compression and 8.78 dynamic compression be to high?
Michael
Old Jan 5, 2005 | 09:52 AM
jcstew02's Avatar
Re: Pump gas motor queston?
problem is pump gas + nitrous = detination. Which is a really bad deal.
Old Jan 5, 2005 | 11:28 AM
sniffin94's Avatar
not really if you run a dedicated fuel system for the nitrous with race fuel. I am going a very similar route, pump gas motor huge shot of the gas
Old Jan 5, 2005 | 09:33 PM
Nitrous is not the issue. I am talking about running the car on street very little and it would be without the nitrous. Race gas only when using nitrous at the track, period.
Michael
Old Jan 5, 2005 | 09:57 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
11.8:1 is very safe. I ran as high as 12.5:1 (not just ran, but RACED) but that was pushing it.
my 401ci motor was 12:1 and I actually ran it on a nitrous a bit on 93 octane, though I dont reccomend it :-D
Old Jan 6, 2005 | 12:19 AM
SStrokerAce's Avatar
The boundries of pump gas all depend on burn, the ability for the motor to take detonation, the coolant and the quality of the fuel.
If you are 100% on that DCR then you will be ok if things are done correctly.
If you never run the juice on pump gas then even better.
Bret
Old Jan 6, 2005 | 10:16 AM
jcstew02's Avatar
I run a 425 CI SBC solid roller 12:1 compresion on the street with Nitrous. But I have to run race fuel..... I tried a mix 50/50 108 and 93 pump and had trouble...
HectorM52
Jul 30, 2017 11:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
