Pulling the motor, and some other ?'s
Old Feb 4, 2003 | 09:19 PM
1FastRedZ's Avatar
Question Pulling the motor, and some other ?'s
I was wondering if you guys knew of any good sites or books on pulling the motor. It would be the first time. I was also interested in what set-up of parts you guys with 383's are running. Best places to go for prices ect... I was thinking of a 383 single turbo set-up. I'm still very much in the planning stages though. Thanks for the input!
Old Feb 4, 2003 | 09:51 PM
StealthElephant's Avatar
What do you need to know about pulling the motor? Make sure to safely remove the fuel lines, unbolt the tranny from the motor, disconnect everything, and pull it out....will slide right out of the tranny....
Old Feb 4, 2003 | 09:52 PM
kmook's Avatar
Advanced Tech Moderator
This definately should be posted in LT1 Tech. I see you already have the motor pulling question posted there, As far as the 383 question i would do a search as it has been discussed quite a few times...
Thank you.
DirtyDaveW
Mar 15, 2015 07:01 PM
transam_388
Mar 15, 2015 11:53 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
