A "pro's" view on engine coatings
Old Jun 27, 2006 | 08:58 PM
  #16
1racerdude's Avatar
Re: A "pro's" view on engine coatings
Originally Posted by SStrokerAce
Nah, with a lot of brazing and epoxy those heads are worth something!
Bret
When ya got the RIGHT heads all that other stuff IS unnecessary.
Like Blue Thunders that will flow 410 on a 4.030 bore 430 on a 4.125 bore, that Richard did for me.
TFS "R" heads ain't no slouch either.
Then ya got them there Yates heads that do real good too.
Old Jun 27, 2006 | 09:17 PM
  #17
SStrokerAce's Avatar
True, nice numbers Richard got out of those puppies. CNC program or hand?
Bret
Old Jun 27, 2006 | 09:23 PM
  #18
1racerdude's Avatar
Bret
Both. He made the CNC program from these heads,they were one of the first pair and his first set.
Probe did a mag article on them 5-6 years ago.
Wish I could afford some of these coatings they are using.
Old Jun 28, 2006 | 06:01 AM
  #19
I get my bearings done at Swain Tech. It's about $100 for me round trip. After usuing usually 2 sets of mains and rods to get what I need for clearance I figure it's worth it.
Bret
Old Jun 28, 2006 | 11:08 AM
  #20
1racerdude's Avatar
Bret
That two set thing is one reason I haven't used any coatings.
Double your pleasure-- double your fun---
Old Jun 28, 2006 | 12:40 PM
  #21
Kevin Blown 95 TA's Avatar
Anybody have experience with the Clevite 77 coated bearings? That's what I used this time. Looked like something similar to Teflon.
Old Jun 28, 2006 | 02:02 PM
  #22
Larry, no I think you misunderstood me.
I set bearing clearances with usually a STD set and either some .001 or HX on both the rods and the mains to get the clearance I want and THEN I package them up and send them out.
If you mark all the bearings you get them back to put them in the same places.
Bret
Old Jun 28, 2006 | 02:03 PM
  #23
I've seen them but haven't gone thru all the standard ones in the shop before I order those in.
Bret
Old Jun 29, 2006 | 02:23 AM
  #24
Camaro_Guru16NY's Avatar
When Darrin talks about the efficency I think he is talking about a lot of things. It's odd but there are things that go on in the intake ports and exhaust ports that will change how much timing a motor needs. The less timing the better, but that is also relative to the stroke and rod length. A F1 motor can take well over 50° at idle, but it's not because of the inefficentcy of the chamber/piston design, it's that there's no stroke in there.
Say if you are running a setup like we commonly run here, the coatings are going to help it more than a Pro Stock motor. Now a old Smog headed setup would benefit even more than a LT setup, since the LT has better chambers, and better thermal properties. Or take something like a Cleveland setup, those things have caverns for ports, bad exhaust ports, bad chambers (even on a 4V 302 head) and compare that to a Yates head which is basically a modern version. The old Cleveland will gain more from coatings.
As for bearing coatings, they are worth it on about anything. If you ever go light on oil, starve the pickup or have a bearing spin they will definately save you money or a motor. Do some digging on coated bearings and a guy called Keith Dorton and see what you come up with. FWIW If I have the time and the budget to coat the bearings in a motor, it's done.
Bret
Bret, how much are you talking $ wise to coat the bearings for a motor and turn around time?
-john
Old Jun 29, 2006 | 02:35 AM
  #25
1racerdude's Avatar
-john
Ya can buy them already coated.
Old Jun 29, 2006 | 02:39 AM
  #26
oh duh, yea i guess i should of realized that. lol
-john
Old Jun 29, 2006 | 02:44 AM
  #27
1racerdude's Avatar
[QUOTE=Camaro_Guru16NY]oh duh, yea i guess i should of realized that. lol
-john[/QUOT[
http://engineparts.com/p_performance_bearings.asp
Go here
Old Jun 29, 2006 | 06:17 AM
  #28
-john
I think the Clevite 77 coated bearings costed me about 50% more than plain H series. It was close to $200 (retail) for rods & mains. I originally was looking for a way to tighten up my clearances by about a half thou and was going to go .001 over on half the inserts, but decided the coated bearings would accomplish the same thing and have the benefit of added insurance. I never regretted spending the extra cash for the better beaings.
Old Jun 30, 2006 | 04:31 AM
  #29
WS6 TA's Avatar
You know, I have yet to see a back to back test with the same parts uncoated and then coated with thermal barriers that show any statistically relevant change in HP or BSFC. Someone recently said they were going to do it using Swain tech’s coatings (swain agreed, one of the few coating’s companies that I really trust) but I never saw any results.
As far as shedding and lubricating coatings, those fit the “extra measure of safety” category, I don’t believe that they give you anything till you have a problem otherwise.
Old Jun 30, 2006 | 08:07 PM
  #30
MachinistOne's Avatar
I dont think anyone has said that they give you a performance edge cause they dont....cranks ride on a layer of oil, not on the bearing. Should a situation arise where the crank does make contact with the bearing, the coating is very beneficial.
So if you consider that you starved it of oil for a bit and now your bearings are still okay because of the coatings, yet your competetor smoked his uncoated bearings and is pulling his motor...yes it is a performance edge.
