Propelene oxide
Old Dec 14, 2007 | 10:16 PM
mdacton's Avatar
Propelene oxide
Anyone have experience with this?
I don't think I ever will at the price it cost.....
So hows it work?
http://www.worldwideracingfuels.com/...oductid=790068
Old Dec 14, 2007 | 11:10 PM
jerminator96's Avatar
So hows it work?
Is that the same propylene oxide that they use in thermobaric bombs? If so, freakin' awesome.
Old Dec 14, 2007 | 11:20 PM
mdacton's Avatar
I don't know about all that, but if you put it on the carpet and she goes faster I might check it out. It sure is expensive so it must do something
Old Dec 15, 2007 | 09:46 AM
cnorton's Avatar
It must be worth something. The 2008 NHRA Rulebook (page 65) says, "the use of propylene oxide is prohibited in all classes." Plus, it seems like I recall something about it being carcinogenic. If you decide to experiment, give us an update, especially if you pick up more than a second and/or start to glow in the dark!
c
Old Dec 15, 2007 | 10:46 AM
AL SS590 M6's Avatar
Moderator
It says 8% increase in power without making any other changes to your setup because it contains oxygen.
Interesting...........
Old Dec 15, 2007 | 11:30 AM
It's used as an accelerator. A basic thermobaric weapon uses principles similar to an internal combustion engine. It is essentially a big tank of fuel with an explosive charge to atomize the fuel in the air, then a secondary charge ignites the fuel.
I believe the propylene oxide in those bombs can reach temperatures over 5000 degrees Fahrenheit though, so I would be careful about putting that in your motor.
Old Dec 15, 2007 | 11:31 AM
mdacton's Avatar
c
I'm going to go to worldwide racing monday and get some. I have to get some other stuff anyway.
I will update how it does, I did talk to someone and they picked up 3 tenths. They are running a big ford in a top sportsman car. went from 7.70 to 7.40. Thats a huge amount of power increase at that level. So I am convinced to try it
Old Dec 15, 2007 | 07:05 PM
marshall93z's Avatar
Fuel-air explosives are nice!
Mike, be careful with that stuff. And I hope you already have kids.
Originally Posted by MSDS
Toxicology
Probable human carcinogen. May alter genetic material. May cause impaired fertility. Human mutagenic data. Harmful by ingestion, inhalation and through skin contact. Serious irritant. Very destructive of mucous membranes. Typical TLV/TWA 20 ppm. Typical STEL 100 ppm.
Old Dec 16, 2007 | 05:33 PM
gota406's Avatar
Info
http://www.shellchemicals.com/propyl...8,1511,00.html
Old Dec 17, 2007 | 06:05 PM
roguedriver's Avatar
It says you can mix it with methanol also. Wonder if you'd be able to mix it with straight methanol in a methanol injection setup and see a gain over straight methanol alone.
Ken R.
Old Dec 17, 2007 | 06:29 PM
tomcowle's Avatar
I've messed with it in the past in both Sprint cars and in testing with a NHRA stocker. What fuel do you currently use? The gains really vary between the fuel types specific gravities.
I call BS on the person picking up 3 tenth on a Top Sportsman application, do the math your talking massive hp gain.
It isn't a "pour in and run fast" fuel additive there is a learning curve to it to maximize its potential.
Honestly, unless your match racing or class racing heads-up save your money, it has alot of health risks (for you and your fellow competitors) and your not going to gain massive hp from its use.
Old Dec 17, 2007 | 06:32 PM
mdacton's Avatar
I'm just using 110 now it a LT1 around 14:1 static. Nice to hear someone that has tried it......sounded too good to be true
Old Dec 17, 2007 | 07:05 PM
Might be too good to be true in your race car, but if you wanted to level a city block in a fairly economical fashion....
Old Dec 27, 2007 | 07:00 PM
camaroLevi's Avatar
my work has propylene glycol smells like (IPA) alcohol as well , we get it in the form of pallets 4 x 55 gallon drums
asilomar244
Jul 12, 2015 05:53 AM
warmeck
Jan 20, 2015 10:29 PM
Onetuffride
Sep 20, 2002 10:11 AM
Vettenut97
Aug 15, 2001 08:21 AM
