Possible to use conventional 400 block and build a 377ci LT1?
Old Aug 8, 2006 | 02:49 PM
  #16
1racerdude's Avatar
Re: Possible to use conventional 400 block and build a 377ci LT1?
Originally Posted by Mike Comp T/A #57
I think you went off topic on this.
In theory, the cylinders should be perfectly round. The thicker the wall thickness the better chance that it will stay round and have a good ring seal. This is were you pick up the horsepower. That's why engine builders use torque plates and block filler. The also check several blocks with the ultasonic gauge before they pick one to use. You can machine 2 different blocks exactly the same and one will make more horsepower than the other on the dyno.
If it's under .200 the the wall is to thin IMO. That's why I said that and you quoted it out of text
I build engines and am well aware of WHAT bores do and don't do..
IF ya take two different blocks that are identical ya won't see a difference, but if ya did like Mike said switch from a block that was to thin and cracked and went to a Bowtie or dart then ya may see some gains.
Ya got 2500 for the block and 2500 for the machine work to get it ready to go? I don't and below 550/600FWHP the factory block is good enough for most.
D1SC383LT4
Jan 26, 2015 01:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
GOATCRAZY
20
Jul 17, 2002 06:06 PM
