possible to change firing order?
Originally posted by Soma07
It can be changed, you would need a custom crank & cam to pull it off though.
LS1 has the "new" GM firing order of 1-8-7-2-6-5-4-3.
The previous V8's used 1-8-4-3-6-5-7-2.
The new firing order was chosen to minimize some vibration or rocking, I believe. Notice than the same cylinders are still paired (1-8, 7-2, 4-3, 6-5).
With a single plenum individual runner system or single plane manifold, there's probably not any power advantage to one or the other. If you were using a dual plane manifold, it might need some work. If you were using 4 into 2 into 1 headers you might have to change the layout.
I've wondered if anyone building older gen SBC's has tried the new firing order. Big problem would be getting cam blanks with the right lobe orientation. That's only money however. Bet there's not much difference in performance.
thanks oldss. i was curious because i've heard that mustangs sound so mean due to firing order and true duals. i was wondering if there would be significant gains from changing this but i guess not thanks again guys
doug
doug
Originally posted by StreamlineZ28
how does changing the firing order make less vibration
is that why the LS1 sounds and feels so much smoother than the LT1
is there anyway to get the Lt1 to rev smoother it is really rough
I doubt that firing order makes the big difference you noticed LT1 vs. LS1.
doug
doug
Since 1997, have you ever heard a car comming down the street, and just "new" it was a mustang, then you look up, and it looks just like you with a different nose. LOL Many ls1's and stangs sound the same, even if the Ls1 has single exhaust, except for the Ls1's with cut outs.(which sound terrible- ls1 with cut out = no no) I heard a car comming down my street awhile back and thought a mustang was comming. Looked up and it was a C5.
If you would like a different sound on an Lt1 try an x pipe and dual exhaust . I hear they sound pretty mean.
I think they changed the ls1 order for smoother idle also, if im not mistaken.
Sergio
Jan 27, 2016 04:27 PM
grabbem88
Mar 18, 2015 01:25 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
