please help, cam may be wrong!
Old Apr 28, 2004 | 07:20 PM
  #16
1racerdude's Avatar
Well you have to try different settings.There is no magic setting to cover all,all engines are different.
An "Old School"way is to bring RPM's down in 4th gear as low as possible (without bucking from cam)and floor it,keep setting timing up until it "PING'S a little at first and goes away rapidly. This may not be the best but it is close.Do this after you make sure the valves are adj correct.
Old Apr 28, 2004 | 10:57 PM
  #17
slashz28's Avatar
Originally posted by 1racerdude
Is this engine SPEED DENSITY?
The cam sounds ok.If you think you have a vacuum issue put a guage on it and FIND OUT.If the valves are to tight it will cause a vacuum issue.
Did it ever start and run right?
Is the timing set back right after the dist moved?
Is the chip in the CPU tuned for the cam?
What is your compression ratio?
Small things like these have to be answered before anything can be said. OTHERWISE it is just a guess!!
another addition: are you getting fuel?? did you check your valve lash yet?
Old Apr 29, 2004 | 01:02 AM
  #18
kandied91z's Avatar
can't check the lash until tomorrow-today afternoon. as far as fuel....isn't a problem. i can fill a dixie cup on startup. it's over fueled.
Old Apr 30, 2004 | 12:02 AM
  #19
slashz28's Avatar
any news? the shop still not helping you out? i doubt your cam beeing "too big" is causing your vacuum issues. i noticed you stated you dont know how to adjust your valves, and that youd look into it. tip: id go with the "up and down" adjustment mathod rather than the "spin the pushrod" method. less likely to overtighten. sorry, cant help yuo with the timing or degreeing, dont know but, ive told you this before and ill tell you again, i love your car dude
Old Apr 30, 2004 | 02:58 AM
  #20
kandied91z's Avatar
thanks for the kind words........i'm learning as i go and trying to fix it. no the shop isn't helping, they have already been paid.
Old May 2, 2004 | 10:19 AM
  #21
nosfed's Avatar
My car has a little bit smaller cam, but with the stock engine management it took forever to start. When I got dfi I added cranking fuel and all was well. You should definately try the other things listed above.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Queens94z28
Nov 20, 2014 06:03 PM
