Piston/heads questions.
Old Jan 11, 2004 | 04:10 PM
smokerZ28's Avatar
Need some info before I can get my heads worked over, any help appreciated.
What is the bore diameter on the Fel-Pro 1074 head gasket?
How much cc is lost in the valve reliefs on the stock LT1 piston?
What is a typical LT1 deck height for the piston crown?
I was advised to post this here also becasue its considered advanced.
Old Jan 11, 2004 | 11:45 PM
smokerZ28's Avatar
anyone? shoebox maybe?
Old Jan 12, 2004 | 03:24 PM
SStrokerAce's Avatar
Re: Piston/heads questions.
4.100 or so is the Diameter of the gaskets.
Typically a 4 valve relief piston is around 6-8cc
Typically a SBC of any sort has the piston in the hole .025
Bret
RUENUF
Mar 13, 2016 03:37 PM
ZXXVIII
Sep 1, 2015 04:14 PM
Aug 28, 2015 07:53 AM
Pestilence
3rd Gen / L98 Engine Tech
Aug 18, 2015 10:16 AM
Bizzomb0707
Oct 9, 2002 04:28 PM
