Pinout for ford TPS
Old Dec 20, 2004 | 05:15 PM
biggtime's Avatar
Pinout for ford TPS
I am doing a single plane intake with a 95mm holley TB, it uses a ford TPS. I know it turns oppisite. Does anybody know what colors go to what GM pin or do i need a fancy TPS? the one i have has a orange / green/ black wire.
Old Dec 20, 2004 | 10:10 PM
atljar's Avatar
Re: Pinout for ford TPS
I had the same thing on my 90mm accufab, and it was giving me all sorts of weird values no matter how it was wired.
Ended up taking a stock GM sensor and grinding down the back half of it to make it sit flush on the TB. Then the GM unit took a half moon shape type shaft, while the ford was a slot. Some epoxy in the GM TPS and fit it to the ford TB slit style. So far this has worked well for me. Good luck
Old Dec 21, 2004 | 12:08 AM
biggtime's Avatar
I thought about that but i might not have to go that route. I am using a Accel DFIV7 so tomorrow i will call them and see if there is something in the program to compensate.
Old Dec 21, 2004 | 01:03 AM
atljar's Avatar
I was told by a reputable source that DFI has a TPS values chart in it somewhere. You can set 0%, and 100% and it scales everything else in between. Good luck
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
