Pics sbc intake converted to lt1 needed
Old Mar 8, 2005 | 09:05 AM
Guss_B's Avatar
Pics needed, sbc intake converted to lt1
I'm looking for pictures of regular SBC carb intakes modified to fit LT1 heads. I have a good idea of what needs to be done but it'd help to see pics so I can viualise the new bolt holes and bolt angles.
I haven't picked an intake yet (havent nearly finalised my combo) but I have seen that some intakes have had different mounting faces over the years, some with more meat around the bolt holes than others. I need pictures to help me know what to look for. I know GMPP makes a carb intake, but I'd rather buy something cheap and used, and convert it myself, on account of having no money plus I may want to go single plane.
I've searched high and low, but the only posts I found were old and the links didn't work.
Old Mar 8, 2005 | 10:57 AM
NOMAD's Avatar
Re: Pics needed, sbc intake converted to lt1
http://nkyfba.homeip.net/uploads/nomad/lt1carb2.jpg.JPG
You really can't see the bolts in the pic though. I went with the RPM airgap, then switched to the GMPP one. Too many oil leaks and vaccum leaks after machining. The GMPP fit on the perfect and has made nice power. Heather couldn't even drive the car with the Airgap one on there just because of the major loss of vaccum. Messes the fuel signal all up and it's a bear to drive.
-Shannon
Old Mar 9, 2005 | 01:48 AM
383 Blwn Bird's Avatar
Re: Pics sbc intake converted to lt1 needed
I have one that Brett Bauer converted( Super vic), Its also fully coated inside and out. He has some pics maybe he'll post them.The intake is for sale only 2 dyno pulls looks brand new. It made great power N/a and on the spray. email if intested
Kevin
Old Mar 9, 2005 | 01:57 AM
SStrokerAce's Avatar
I remember that one! ;-)
Old Mar 9, 2005 | 06:56 AM
Dave69Z's Avatar
Kevin
You have an email to your yahoo account about the Super Vic.
Dave
Old Mar 9, 2005 | 02:54 PM
94 guy's Avatar
how about posting some pics? why are you getting rid of it if it made good power?
Old Mar 9, 2005 | 04:08 PM
Dave69Z's Avatar
I believe the reason is in his sig.....
Dave
Old Mar 9, 2005 | 05:39 PM
94 guy's Avatar
what's the new setup?
Old Mar 9, 2005 | 05:50 PM
Dave69Z's Avatar
From his sig....
"New combo 502,Carb,BIG Solid roller,ysi Vortech,TH400w/Brake,9inch,
Wheels up.......! "
Old Mar 9, 2005 | 11:52 PM
Working on a big block, my small block split in two oh well.
Kevin
Old Mar 10, 2005 | 12:06 AM
Bone Daddy's Avatar
There is plenty of pics and information on lt1intake.com
Old Mar 10, 2005 | 09:57 PM
Kevins last combo made some stink too NA and N2O.... takes a big bit of N2O to break a block in 2
Bret
Old Mar 11, 2005 | 02:16 AM
1racerdude's Avatar
Bret
Ford 302's do that regular on a 250 shot or better.
Old Mar 11, 2005 | 08:59 AM
Mine made almost double from what a 302 will crack from.
Old Mar 11, 2005 | 10:34 AM
1racerdude's Avatar
That's a LOT of hose!!!!!!!
