Pics of LT4 with distributor.
Old Feb 23, 2004 | 11:06 AM
96Z28SS's Avatar
I finished my LT4 with the distributor mod. Here are some pics for those that are curious. There is plenty of room under the cowl for a dist.
www.96z28ss.cz28.com/photo3.html
Rob
Old Feb 23, 2004 | 01:12 PM
SStrokerAce's Avatar
Pretty good job. I have one in the shop right now that's almost done.
I just mill the back of the intake flat and weld a plate on there rather than clearance the dam things, take em all the way off.
Fun part is getting the hole in the right spot!
Bret
Old Feb 23, 2004 | 01:55 PM
Sean94Z's Avatar
Looks great. What company did you have do the first one?
--Sean
Old Feb 23, 2004 | 03:16 PM
Maldo's Avatar
Re: Pics of LT4 with distributor.
Rob
Hi really like your set up ..... can you give more info on how you set it you and what it took to make it work. like are you still using the stock pcm etc.
Jim
Old Feb 23, 2004 | 03:36 PM
96Z28SS's Avatar
Re: Re: Pics of LT4 with distributor.
Jim
to make it work you need a different PCM I'm using a F.A.S.T system piggy backed to the stock PCM so that the guages and A/C work.
SStorkerAce,
I made a cradle so the intake sits at the right angle so all you have to do is machine the hole straight down. I was thinking about machining the back off straight but I got lazy.
Rob
Fastbird93
Apr 9, 2016 07:01 PM
k1996z28
Apr 13, 2015 06:54 PM
nikolt1
Feb 27, 2015 09:10 PM
95chwagon
Jan 13, 2015 09:19 PM
