PC to ALDL question, ie. programming with a homeade PC-ALDL cable
Old Aug 5, 2002 | 11:51 PM
MyGreenBabyZ's Avatar
Question PC to ALDL question, ie. programming with a homeade PC-ALDL cable
I found this topic in LT-1 Tech and im not really getting any responces (probably because im "leaching" of the original topic )
Well long story short. I would like to make my own PC to ALDL cable (to save some money) and i was wondering if i could use the interface to do any programming with a program like LT_1Edit.
Topic in LT-1 Tech: Topic
ALDL Schematic in Question: ALDL MONITOR
Edit: What about the 10K Ohm Resistor between A and B? will that be needed for my car?
Thanks alot,
T.C.
1994 Polo Green Camaro Z-28 A4
Modifications - Honker CAI, B&M Trans-Kit, MAC 1 5/8" Shorties, O.R. Y-Pipe, CHM Cutout, MPP2 Electric Cutout Plate, LT-4 KM, !AIR, !TB, !CAT, !TBAF, MSD 8.5MM's, MSD Coil, and a Bunch of Poly Bushings.
Best times: 13.97 at 101.06 MPH w/ a 2.26 60' and a 1.2 RT at Milan Dragway In Michigan
AIM : OneFireForU
My Camaro Site
[This message has been edited by MyGreenBabyZ (edited August 06, 2002).]
Old Aug 6, 2002 | 06:55 AM
kmook's Avatar
Advanced Tech Moderator
Post
<font face="Verdana, Arial" size="2">Originally posted by MyGreenBabyZ:
and i was wondering if i could use the interface to do any programming with a program like LT_1Edit.</font>
If you can use it for diagnostics successfully you should be able to use it for programming.
</font>
From the looks of that article you would not need it.
But since we do have a Computer Diagnostics and Programming forum and neither your question or Mikael's question were posted there i think it would be appropriate to try in that forum, so i'll move this there.
Thanks.
Ken
Parts Wanted
Mar 17, 2015 11:24 PM
grabbem88
Feb 10, 2015 06:20 PM
edman
Jan 25, 2015 02:41 PM
Jul 4, 2005 05:00 PM
